Panasonic TX-P42S11B - 7 Blink Code
  • Fool2cool
    • Sep 2012
    • 17
    Hi all, first real TV repair attempt for me!
    I have this Panasonic plasma tv on my bench that had the 7 blink code problem, I disconnect the SU and SD boards and still had 7 blink codes, I disconnected the SC board and got 6 blink codes.
    And now here's where I messed up big time, I read about testing SC by shorting the SC50 connector with SU and SD disconnected, however I failed to read the part about also removing the VF_GND screws. I promptly turned the TV on and a nice smell of burning greeted me from around the SC50 area.
    Testing SC with SC50 shorted AND the screws removed now causes the SC board to sing some very interesting tunes :/
    Can anyone tell me what components I'm likely to of released the magic smoke from so I can attempt to get back to my original fault
    Thank you
    Chaz
  • chrishenderson69
    • Jun 2013
    • 3
    • united kingdom
    Re: Panasonic TX-P42S11B - 7 Blink Code
    hi i am only guessing as i have done the same repair but you may have fried the sc board it might be cheaper to buy a replacement about £40 from flattvparts in portsmouth it might be less than what i paid for mine depending on model etc
    Chris
    • Fool2cool
      • Sep 2012
      • 17
      Yeah I did consider that, but I'm also worried that the original fault wasn't the SC board, the fault history is that it fell off a stand and onto the floor, so I'm wondering if it could be something like a shorted panel? I don't want to shell out for an SC board if it does turn out to be that although I might have to.
      Thank you for the quick reply and advice
      • tw2005
        • Oct 2011
        • 6458
        When you say tunes, do you mean loud buzzing? Is the board secured with all it's screws.
        Second time around did the TV startup with no blinks?
        edit: just read the bit about it failing after hitting the floor. I'd be suspect of the panel, may be what blew the buffers/sc and yeah you could end up replacing those to find the panel is broken/shorted.
        Don't know how you'd check except obvious cracking?
        • Fool2cool
          • Sep 2012
          • 17
          Second time round with the 4 vf_gnd screws removed and SU and SD disconnected the SC board didn't so much buzz as more ring like a dial up modem finishing in a continuous buzz and a solid green light.
          Thank you
          • tw2005
            • Oct 2011
            • 6458
            The boards do resonate especially if not fully mounted up, I have installed SC boards for testing and had the odd one make some weird noises and it's always been due to the pcb resonating but always goes when everthing is mounted including the buffers.
            Solid green sounds like it passed startup so the SC is potentially ok. have no answer for the smoke, the buffers would be suspect since you have no blinks, but million dollar question is the panel?
            Shorted panels can make weird noises too, and I've only tried fixing one TV to find the panel was shorted, and yeah the noise it made could be compared to a dial-up modem?
            Not sure how the panasonic handles bad panels, I'd expect a shutdown and a SOS but with no buffers maybe it can't detect it?
            TOM will have a better idea I expect about shorted panel.
            That particular SC board like some other Panasonic versions are very hard to find. probably worth more than the broken TV on it's own?
              Shorted panel will cause SOS6/SOS7 if it kills buffers/SC; SOS8 otherwise.
              • Fool2cool
                • Sep 2012
                • 17
                So the fact I get a solid green light with SC50 shorted would indicate that SC is possibly good and SU,SD are blown? But a shorted panel could of caused them to go?
                Thank you for all your help so far!
                  You need SU/SD in panel to be certain but if TV was dropped I would be thinking panel is dud.
                  • tw2005
                    • Oct 2011
                    • 6458
                    If solid green is the normal onstate I would expect most likely it's good although I have managed to create a situation during a rebuild of a SC board where it passed, was humming and fired the panel but no drive signal to generate an image due to a faulty octal buffer IC but that was damaged during fault finding the board. I put that as fairly unlikely in your case.
                    For our models it's flashing green on startup, solid when running, red on standby, blinking red for SOS fault codes.
                    • Fool2cool
                      • Sep 2012
                      • 17
                      Yeah I get flashing green during startup then a solid green after a short while, I do worry I might of damaged something during fault finding, I'm all set up here to do surface mount rework the problem comes with tracking the fault down as always! Where could I check to see if I was generating a drive signal?
                      Does anyone have the service manual for this set? I found the service manual for TX-P42S10B but I don't know what the differences would be between the 10B and the 11B that I have.
                      Also can anyone explain why I had to remove the vf_gnd screws to perform the SC50 test?
                      Also just had another thought, is it worthwhile removing the panel from the chassis to do a visual inspection? I know someone in a previous thread mentioned that after removing the panel from the chassis and something else from the top of the panel they could quite easily see a crack.
                      Thanks again
                      • tw2005
                        • Oct 2011
                        • 6458
                        Same SC boards so maybe chassis or mainboard?
                        • Fool2cool
                          • Sep 2012
                          • 17
                          Hi all, I did some more reading and saw that I should be able to test the buffer boards for a short with a multimeter, I tested both buffer boards. The lower buffer board appears to have a partial short to floating ground on the 4th connector up on 3 pins, it isn't a dead short though, it measures about 4 ohms. Does this mean the lower buffer board is blown?
                          Charles
                          • tw2005
                            • Oct 2011
                            • 6458
                            If you're taliking from gnd - the buffer ribbon connectors, yes it's knackered.
                            • Fool2cool
                              • Sep 2012
                              • 17
                              I'm talking from VF_GND to the ribbon connectors yes
                              • Fool2cool
                                • Sep 2012
                                • 17
                                Hi all, I replaced the SD board and managed to get a picture up but I know seem to have a panel fault? There is a black horizontal stripe 1 pixel wide which stops just short of the right hand side of the screen and there appears to be an actual mark on the panel at that point when the panel is turned off, it looks like a tiny black fleck. There is also a red horizontal line that intersects the horizontal line where the mark is.
                                Pictures attached
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Well that's a lot further than I expected you'd get. I wonder if it's possible the panel is damaged from impact but all the gas did not escape?
                                  never seen a line stop like that horizontally, normally I'd be thinking a reseat of the buffer connector.
                                  At least you know which boards work now.
                                  • Fool2cool
                                    • Sep 2012
                                    • 17
                                    Haha should I take that as a compliment?
                                    Yeah its very strange that the line just stops, and you can actually see a physical mark with the panel turned off. The data connector on the C1 board I think it is on the far right where the vertical line is also gets very hot, I think if I understand correctly these have a chip on flex? and the large metal bracket is a heatsink?
                                    I've also re-seated the buffer connector a few times but it doesn't help.
                                    Thank you
                                      That is quite likely a panel problem due to misaligned electrode (factory defect)
                                      Page 53.
                                      • Fool2cool
                                        • Sep 2012
                                        • 17
                                        Page 53.
                                        Thank you for the link Tom, is this a problem you've come across before?
                                        • rmacintosh
                                          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                          by rmacintosh
                                          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                          The symptoms of the tv ar as follows:
                                          • Plug AC in to back of TV
                                          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                          • The 3 blink code is given by the power LED
                                          • If the TV is unplugged and then
                                          03-14-2020, 12:24 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • LongLiveMyPlasma
                                          Panasonic TC-P42ST30: Repair for 14 blink code
                                          by LongLiveMyPlasma
                                          My beloved Panasonic TC-P42ST30 has been stricken with the 14 blink code.
                                          I've spent many hours reading through forums, watching YouTube videos and reading the Panasonic plasma troubleshooting guide. But I'm a novice at this, and still need some help to cross the finish line.
                                          I understand the Panasonic troubleshooting guide suggests that the 14 blink code usually means there's a problem with either P-board or A-board. However, I also learned the problem frequently rests with the SN-board.
                                          Using my multi-meter, I was able to confirm the P-11 pin on the...
                                          05-18-2020, 10:48 AM
                                        • orbit417
                                          Panasonic Plasma tc-p55vt50 6 blink error code
                                          by orbit417
                                          Hi All,
                                          Thank you in advance for your advice.
                                          I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
                                          I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
                                          I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
                                          04-14-2021, 09:11 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
