kdl-52wl135 with streaks in the screen
  • noskire
    • Jun 2013
    • us
    Hello!
    I have a sony kdl-52wl135 here that has two problems... first problem is there is a faint greenish band of about 3 inches thick that runs vertical in the left side of the tv about a third of the way into the screen. This band has been here for quite some time but has been tolerable till now.
    2nd problem is there are now many little vertical streaks in the screen spaced about every 1/4 an inch apart that only seem to be an issue when there is some form of an imput playing. If I go to a solid menu screen there are no signs of the streaks which tells me it has something to do with the transmission of live video content and not the screen itself?
    If I could at least fix the later problem I would be content but if I end up opening up the tv to fix one problem may as well see about fixing both.
    Thanks for any feedback!
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
