Polaroid FLM373B Story
  • leadlike
    • Oct 2010
    I had a coworker ask me to repair one of these. He could not get it to power up, and it looks like he bridged the main fuse, causing the filter caps to blow.
    A simple recap of the entire board got the set going again, but I thought a few observations would help someone who wished to repair one of these in the future:
    I could not find a revision number on the set or the power supply board, but the two caps that are typically id'd as the main troublemakers on this tv were not the junky Capxon brand, but were some nice 105c Nichicons. Perhaps the manufacturer had too many of these failing due to those two crummy caps. All ecaps were replaced with either 105c Nichicons or Panasonic caps. Total cost from Mouser was about 15 bucks with shipping.
    In most recappings I have seen on this forum, folks tend to leave the caps under the heat sinks alone. There are three of these, and on my set, all three tested for leakage. Replacement may seem intimidating, but I was able to feed the long leads of the new caps through the through holes on the board without any issue. One of these caps was totally blown out on my board, so please don't ignore these when redoing your set.
    Performance of the set is so so. So so picture, and pretty mediocre audio. Still, it was only 30 minutes worth of work, and the set now has 10 hours on it, so it looks like it will work just fine. Hopefully these observations will be helpful to someone in the future.
  • Elysarian
    • Mar 2013
    • 200
    Re: Polaroid FLM373B Story
    Completely agree on the caps under heatsinks thing, if any cap is going to get cooked it'll be ones that are poorly ventilated with a nice heat source surrounding them
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      sometimes i think the design is intentional.just out of warrenty the cheap noname caps let go.
      just fixed an akai for a neighbor.same poor design with crapxon under heatsinks.
      these dont last under the best conditions!
      • TJVJR
        • Jul 2013
        • 25
        I am working on this same model and I replaced the 2 caps that most commonly fail about a year ago. It worked good until a few days ago , now it does nothing. I found the larger cap above the other 2 was bad as well as one under the heatsink , The rest look good but it still doesn't have power. I found only 2 caps under the heatsink , are there supposed to be 3 ?
          Where did you buy your replacement capacitors from?
          • TJVJR
            • Jul 2013
            • 25
            A small electronics store. I am not sure of brand but I have removed a couple ( the last 2 I replaced ) from a old working monitor but after the reading I have done on this site I don't think that was a good idea. I was in a hurry to replace them as this is our primary tv .My only means of testing the caps is visual and a multi meter . I believe I should replace all of the caps on the ps with new ones regardless of the way they look. What brand should I use ?
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
