Samsung PS42B450 Y Main
  • thestigp11gt
    • Jun 2013
    • 30
    • Scotland
    Hi, I have recently been given a Samsung plasma TV, which was faulty. After diagnosing the TV it appeared that the Y Main board was at fault. I ordered a brand new Y Main Board, fitted it, switched the TV on and a nice picture appeared, after about 5 minutes of the TV being on, the screen started to go darker and darker and then the TV switched off, and the same problem it initially had started again, The clicking on and off sound.
    Could this just be a faulty part also and bad luck?
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung PS42B450 Y Main
    Have you used a multimeter to check your X-main for faulty components? Also, I'd check the Y-main again without powering on the set. It's possible that your Y-main is still good, but you could possibly ruin it if you turn on the TV again. Unless your chassis is somehow different from what's shown in the attached pic, the X-main appears to be receiving power from the Y-main.
    LG Plasma Mal-Discharge Correction Service
      On these sets, the X-main chains power from the Y-main, but also combines energy recovery.
      Therefore, if you cannot test both boards and find they are OK, you should replace both at the same time, and also should consider the buffer, though on these sets the buffer rarely fails when the Y-main goes bad.
      • thestigp11gt
        • Jun 2013
        • 30
        • Scotland
        Thankyou so much for the replies. When I disconnect the X Main, the TV powers up, as you can hear the start up tone. and powers down with the command from the remote control. I am told that a faulty X Buffer can cause the X Main to pop, and I am wondering if this is the case.
        Also that PS42B450 looks different to the Samsung TV I have
          There is no such thing as an X buffer with regards to the X-main; the little board attached to it can be called an X buffer but not really as it's just a glorified connector assembly.
          • thestigp11gt
            • Jun 2013
            • 30
            • Scotland
            So what is the name of the long board on the left hand side of the TV:
              Y-buffer, connected to the Y-main.
              • capkid
                • Oct 2010
                • 1339
                It's not applicable to this Samsung, but some of them do have X-buffers.
                  On some, I have seen a few components on them, but most are just glorified connector assemblies.
                  • thestigp11gt
                    • Jun 2013
                    • 30
                    • Scotland
                    Sorry guys, I had completely mistyped one of my replies.
                    I meant to say that I was told that the Y buffer should be replaced when the Y main is replaced. Can the Y buffer cause Y main failure?
                    If I disconnect the Y Main, then the TV powers up, and you can hear the start-up tone, when the Y main is then reconnected then the TV just clicks.
                    How would I test each of the boards to verify if they are dead or not?
                      Yes, a bad Y buffer can kill the Y main.
                      You can test the buffer:
                      http://www.youtube.com/watch?v=51SZsfH60EY
                      • thestigp11gt
                        • Jun 2013
                        • 30
                        • Scotland
                        Done a test as shown on that video, and it appears that the Y Buffer appears to be OK.
                          There is one more test I didn't feature in the video, but it involves testing from the sus OUT to the Vad out pins, if you post a picture of your buffer I will highlight the test to be done.
                          • thestigp11gt
                            • Jun 2013
                            • 30
                            • Scotland
                            I have put up both a picture of the Y Main and Y Buffer
                            How would I go about testing the Y Main to see if it is faulty also?
                              Here is where to test; use diode mode on your meter. Try both ways, not just as indicated.
                              • thestigp11gt
                                • Jun 2013
                                • 30
                                • Scotland
                                I am getting a reading of ~.900 (give or take a few values) when Positive probe is on Y main connector. No beep though.
                                  But you see nothing the other way? The buffer is most likely OK then.
                                  • thestigp11gt
                                    • Jun 2013
                                    • 30
                                    • Scotland
                                    Could the X Main be popping the Y main?
                                      That is not only possible, it is quite likely.
                                      A bad X-main on these sets risks damage to the Y-main, and vice versa, due to how the energy recovery circuit is chained.
                                      • thestigp11gt
                                        • Jun 2013
                                        • 30
                                        • Scotland
                                        So it is best just replacing them both. How can one test these boards?
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          Yesterday, 11:35 PM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
