So I'm looking to swap the plasma panels in these tv's. they are almost identical. But couple of questions. The upper and lower buffers are different. The screen has 10 tabs going to the buffers on the p50hdm and the other has only 8. I'm looking to swap the actual screen. Is this going to be possible. The p50hdtv10a works fine but the screen has a kinda multi colored line down the right side and its hard to see on some colors. And has some red dots on start up but go away after a while. This is a flip tv so I literally only have like 55 bucks into it. Should I just sell it like that condition or try the screen swap. The p50hdm I think needs upper and lower buffers and ysus cause it gets no picture but has audio. Let me know what y'all think.
Vizio p50hdm and p50hdtv10a panel swap
Tags: None
Re: Vizio p50hdm and p50hdtv10a panel swap
It's very unlikely to work. How are you going to connect 8 connectors to 10 ribbons or vice versa?
Is one panel made by LG and the other Samsung? In which case, basically no chance of that working.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
i know the p50hdtv10a is a samsung and now that im looking at it the other is a lg. dang. now i gotta figure out wether i wanna fix the p50hdm i think it needs ysus and buffers. or should i say if i replace the ysus i would replace the buffers. Isnt that recomended cause if one of the ydrvtp or bt is bad, cant it hurt the new ysus board.Comment
also what do you think i could get for the p50hdtv10a with a sometimes hard to see line down the screen plus occasional red dots on start upComment
Vertical line(s) on screen is a bad plasma panel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
yea i know its a bad panel but the screen still works still shows the whole picture and has sound. What do you think the tv is worth?Comment
I have very little knowledge of US TV prices, but if you think the TV is still watchable it could be OK as a basement TV for someone.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
and for me to get the p50hdm it has power and sound but no picture. im assuming the ysus. when you replace the ysus board dont you have to replace the buffers at the same time.Comment
On a Samsung panel yeah Y-main plus buffers is pretty common failure.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
th p50hdm has a lg panel. how can i test to see which board needs replacingComment
Same Y-sus plus often buffers but not always.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by JeryswanHey everyone
I remember some time ago being able to program a main board to a specific panel size/model. I've tried everything I can find online to get into a service menu on this TV with no avail. Here is what it looks like currently.... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
