Lg Plasma TV problems
  • iadrian
    • May 2013
    • 17
    • Serbia
    Hello everybody,
    I have a problem with my LG plasma TV.
    The problem is the TV sometimes turns on, sometimes not. When it doesn`t turn on it makes the "clicking sound".
    It also turns off by itself when it works after 30 minutes or so.
    I have read many tutorials and troubleshooting about the "clicking problem" and had no success. I have checked EVERY capacitor in the TV, especially on the power board and everything is OK.
    I have even changed the power stabilizer on the power source hopping that would solve this problem but no luck.
    As a last resort, I have taken my TV to the "TV guy" in my town. He said that the TV Y-board is overheating and that is causing this problems.
    After that, I have places a computer fan directly over that board, connected to the power source, the fan fits perfectly but the TV is still broken.
    If anyone can help, I would appreciate it.
    Thank you,
    Adrian
    Re: Lg Plasma TV problems
    Can you:
    a) tell us the model of your TV e.g. 50PK3800
    b) post pictures of inside the TV and of each major circuit board, photos should be clear and greater than 1280x1024 resolution.
    • iadrian
      • May 2013
      • 17
      • Serbia
      1) TV model is: LG 42PC1R-ZH
      2) I will post hi res images tomorrow(I can`t open it right now) of every board and the fan modification I made.
      Greetings.
      • iadrian
        • May 2013
        • 17
        • Serbia
        Here are the pictures of the TV boards.
        The whole TV:
        The power board:
        The processor board:
        The power stabilizer I changed on the power board:
        The Y board(I added the fan):
        The Z board:
          Your Z board is actually a Y-sus and the Y board (with your added fan) is a Z-sus
          OK, here's a connector on the board.
          There's a pin marked AC-DET. While the set is operating, measure the voltage on this pin. To do this, set your meter to 20V DC range, put the black probe on a part of the metal frame, and the red probe should touch the metal sheaf around the pin. Connector must be installed and the TV should be working.
          If at any point it drops out, this may be your problem.
          You may find it convenient to put a long wire in the connector and set the meter up outside the TV and monitor it while watching the screen.
          And please also check it while it won't turn on at all.
          • iadrian
            • May 2013
            • 17
            • Serbia
            I have measured the requested data. There are 13 pins.
            Results:
            Declared in order:
            3.3v | G | 6 | G | G | 5 | 5 | 5 | VS | G | 5 | RL ON| AC Det|
            Measured:
            4.7v | G | 5.66| G | G | 4.7 | 4.8 | 5.1 | 4.8 | G | 4.7 | 4.8| 4.5|
            From this data, I have noticed only a strange reading from 3.3V pin to 4.7V.
            Is that maybe the problem?
            The AC-DET pin, the last pin, is pretty steady at 4.55V, sometimes it goes to 4.54V or 4.56V but only for a moment.
            The problem usually manifests after turning the the ON - OFF. After you shut it down it wound turn on for a while. I have done this now a couple of times, (ON - OFF) and it works now but the AC-DET pin now has 4.4V.
              Can you show me what range your multimeter was set to?
              • iadrian
                • May 2013
                • 17
                • Serbia
                As you said, 20V DC.
                Here is the image in real time measurement of the AC-DET pin :
                  4.5V is good, the set was running with that? What about when it cuts out or when it fails to start?
                  • iadrian
                    • May 2013
                    • 17
                    • Serbia
                    Yes, I measured that while the TV is running.
                    That is the problem, now the TV is not failing, it is still working . I will try to turn it off an on a couple of more times to see if it will fail.
                    When I turn it off and back on, the AC DET pin has 4.3V and after a while, 4.4 or 4.5.
                    What about the 3.3V pin? It has 4.7V. That is ok?
                      The 3.3V isn't right, but since it's so close to the 5V measurement I'm tempted to think it's a misprint -- I've seen this several times before.
                      • iadrian
                        • May 2013
                        • 17
                        • Serbia
                        I have turned it off an on for 11 times and it is working! I can`t believe it.
                        It is usually showing the problem immediately after the first power off.
                        When I turn it off and back on, the AC DET pin has 4.37V and after a while, 4.4 or 4.5.
                        I will test it all day and report any new data.
                        • iadrian
                          • May 2013
                          • 17
                          • Serbia
                          Correction! It just showed the problem. Back with information.
                          • iadrian
                            • May 2013
                            • 17
                            • Serbia
                            After I turned it off it didn`t turned on again. It makes the "clicking sound" and I managed to turn it on again.
                            Now the AC DET is 4.2V and when the TV is turned off is 4.7V.
                            When he tried to turn on (clicking sound) the AC DET varied from 4.7V to 1 V.
                            Now it works again.
                            Any ideas ?
                              You would appear to have an AC detect fault then, good, this is usually easily cured.
                              Can you provide a picture of under these components?
                              • iadrian
                                • May 2013
                                • 17
                                • Serbia
                                Yes. In 5 min.
                                • iadrian
                                  • May 2013
                                  • 17
                                  • Serbia
                                  Here it is:
                                  Except for one suspicious soldier point (maybe it needs to be re-soldered) I see nothing strange.
                                    I don't know how fast Serbian internet is, but please stop adding photos directly to posts. Just attach them. My 1Mbit internet spent a minute loading this page.
                                    Place solder joints across the indicated points, which will inhibit the AC detect feature.
                                    Disadvantage with doing this is the speakers can sometimes make a noise when the set power is unplugged while running. However, aside from this, there appears to be no disadvantage from doing the AC detect mod.
                                    • iadrian
                                      • May 2013
                                      • 17
                                      • Serbia
                                      Sorry, I will attach them in the future. I have a high speed connection at my home (24 Mbit).
                                      You mean to join this pins??? I am a beginner at electronics and I have to ask I always fear for the worst case possible.
                                      Are you sure this exact pins? because the board is upside down.
                                      If I do this, it can`t explode or something ?
                                        I've done this repair before, as have others, but only on different power supply boards in similar LG models. I haven't blown anything up yet, neither have others. However, with any repair comes the risk of failure or damage, and I can't guarantee 100% success.
                                        Yes, you need to bridge the two points I have highlighted with solder. Be VERY careful not to bridge any other two points.
                                        In the new house I am moving into, we will have 80 Mbit internet, so I may not complain so much, but for now I have to put up with the oversold ADSL network.
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • novak2
                                          Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                          by novak2
                                          Hello there,
                                          I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                          The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                          From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                          Thanks in advance.
                                          09-25-2020, 02:34 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
