Lg Plasma TV problems
  • iadrian
    • May 2013
    • 17
    • Serbia
    Re: Lg Plasma TV problems
    Of course, I am just afraid of scenarios like big explosion and similar .
    WOW, that is high speed !
    I`l do that now and come back with info in approximately 20 minutes.
    Thanks!!!
      You can see my thought process for this repair on a 42" LG, with a slightly different power supply and complete refusal to power up:
      https://www.badcaps.net/forum/showth...ghlight=42pc1d
      and many others with a similar problem.
      • iadrian
        • May 2013
        • 17
        • Serbia
        Ok. I have done as you said.
        Good thing is nothing exploded .
        The TV turned on and everything looks fine.
        I will test it and come back when I have new information.
        Thank you !!!
        • iadrian
          • May 2013
          • 17
          • Serbia
          I have turned it on and off for 40 times and it works!
          It looks like this solved the problem!
          Why does this problem occur? What is that AC check for?
            I'm not 100% certain on what is going wrong, but my theory boils down to this:-
            The AC detect circuit is there to monitor AC power input and see if it is stable and to make sure the set can operate properly. It needs to work from 100V (160V DC) to 250V AC (360V DC) so has to have a wide range.
            So it probably detects any signal beyond around 80-100V DC as being good. As mains surges/transients* and time goes on the reference circuit drifts. Over time maybe it eventually wants 350V DC to work (after it has drifted and got worse and worse.)
            Your AC line voltage varies over the day, with load on the neighbourhood, grid demand, local household load etc -- basically appearing random to the average person. Slight variations prevent the set from always working. but in a seemingly random way.
            *Transients: around 5~10 per day in excess of 500V AC typically up to 1000V AC. Few if any surge suppressors actually suppress this.
            • iadrian
              • May 2013
              • 17
              • Serbia
              #26
              I understand.
              Thank you a lot and if I can do anything for you just ask!
              This TV was doomed to the trash because nobody in my city could fix it. And the last "TV guy" said it can`t be repaired.
              If the problem reoccur I will contact you but I think this repair did the job.
              Greetings!
              • Sisko
                Onkyo-593 No power and now clicking sound
                by Sisko
                Hi all!!
                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                10-03-2025, 02:18 PM
              • B0r1s
                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                by B0r1s
                PSU - BN44-00878A
                Symptoms:
                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                A weak clicking sound was coming from the transformer.
                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                Progress:
                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                01-17-2023, 04:58 PM
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
              • novak2
                Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                by novak2
                Hello there,
                I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                Thanks in advance.
                09-25-2020, 02:34 PM
              • Hondaman
                USB problems?
                by Hondaman
                Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                08-12-2024, 03:26 PM
