Asda Onn 32" LCD TV startup issues
  • Jimmy Jangle
    • Jun 2013
    • 30
    Hi, recently our TV in our bedroom has developed a fault where it stays in standby; any attempts to turn on by remote, or by pressing ch -/+ on the set, makes it come on, but then goes back to standby after 2-5 seconds.
    Rather than buying a new TV (as it's only our bedroom one) or paying for a repair, I though I'd come on here, as I'm fairly competent with a soldering iron.
    It's an Asda Onn model - I've opened the chassis and lo and behold, it's a Vestel 17PW20.2 (at least that's what I believe as the pics online are virtually the same). Most of the caps look OK, barring one (which I've highlighted, this is actually a pic from elsewhere as I'm in work so can't take pic atm), which is black on top - could this be the cause?
    My question is, as I'm going to go in myself to do it, am I better off ordering a new PSU board altogether, or should I order replacement caps?
    Re: Asda Onn 32" LCD TV startup issues
    You may have a bad electrolytic capacitor, but it is more likely you have the bad poly capacitors on the primary or bad PFC section. Very common. For inexperienced users, I always suggest a simple swap of the 17PW20 and 17PW15 supplies. A 17PW20.2 can usually be replaced with a 17PW15-8 with no issues.
    • Jimmy Jangle
      • Jun 2013
      • 30
      Fair enough - how easy are we talking for a straight swap?
      Does it involve just a simple disconnect/reconnect, screw job?
      I'm still half-in/half-out over seeing posts about capacitors zapping you, etc. Will I need to discharge them, and if so, how? I'm probably going to need to invest in some tools, as all I have is a soldering iron (and even that's MIA at the moment as lent to sister-in-law!)
      I'll put a pic up later of the PSU to remove any doubt, thanks Tom!
        Simply disconnect & unscrew.
        These PSU are generally safe if left for a few minutes to self discharge.
        • Jimmy Jangle
          • Jun 2013
          • 30
          Finally got round to this. Got a kit off eBay, board turned out to be a 17PW20-1. Replaced C877, C878, IC829, C817, C801, C901, and C892.
          But still nothing, just the flashing LED.
          Noticed that the caps on C818 and one next to it (same size as C818) have a bulge on top of them, and another at C838 has a black top.
          Should I replace these too, as they didn't come in the kit?
          • Jimmy Jangle
            • Jun 2013
            • 30
            --UPDATE--
            Ordered 2 Panasonic 4700 uF 6.3v caps - came yesterday.
            Got home from work, removed C818 and C857, replaced with the new caps.
            Put back together, plugged in, pressed power button, solid blue led.
            Pressed CH+ button, TV came on - Happy as Larry
              Nice one. Glad to hear. Another TV saved from the dump.
              As a general rule if I ever see a bad (bulging) cap I'll replace it.
              • DaveM62
                • Jun 2014
                Just a reply to confirm my findings. Sympton: FST won't come out of standby.
                5V present. Bottom left of pcb, white multiplug on right, right hand end, red wire. Voltmeter between red wire and chassis. I think this is PL805.
                Black multiplug (PL802?) left side. O volts between red wire and chassis. This goes to 24V when the channel button is pressed, but immediately goes back to zero.
                (See video on youtube -Matsui MAT32LW507 Power supply repair 17PW20-1)
                I replaced 2 bulging capacitors, C818 and C857 (4700uF, anything above 6.3V - I found some 10V caps in my spares box) 24V stays high and set powers up. Well chuffed!
                • vinceroger69
                  • Mar 2012
                  • 6714
                  cool another tv fixed and saved from land fill its a good job there are sites like this badcaps and others like youtube really helps us in doing repairs.
                  • estabilito
                    Acer Nitro AN515-55 weird behaviour on startup
                    by estabilito
                    Hi, I've just repaired acer nitro an515-55 with specs:
                    i7-10750h, rtx2060.
                    Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                    After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                    i've tried different bios, different vbios and same behaviour - clean windows install too.
                    Do you have any idea?
                    08-13-2025, 02:52 PM
                  • SoulFreeze
                    Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                    by SoulFreeze
                    Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                    After repairing the above issue, I realized the following remaining problem,
                    Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                    The computer recognizes headphones are connected and displays a popup in windows
                    Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                    06-21-2025, 09:53 AM
                  • Nagyesz
                    Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                    by Nagyesz
                    I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                    All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                    How can I extend its lifespan? Could reflow help?
                    It has ryzen 5 5500h, rtx 2050, no soldered ram.
                    Example of the artifacts:
                    03-01-2025, 11:11 AM
                  • BMCappelletti
                    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                    by BMCappelletti
                    Hi everyone.
                    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                    02-18-2025, 12:22 PM
                  • pwnjuice
                    Bitlocker issues
                    by pwnjuice
                    Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                    Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                    Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                    01-06-2025, 05:33 PM
