Black Lines on LG Plasma
  • barrybrown
    • Jun 2013
    I'm new to this forum and hoping someone can provide some guidance on a problem I'm experiencing with a LG 60PS60 plasma panel. Every other pixel row from top to bottom is black. Can't tell whether it's all even numbered lines or odd numbered, but one or the other is not working. Sometimes, when the set is first turned on all rows are working, but soon half of them disappear. Also on turn on, there is a period of a few seconds when all pixel rows have a dim brightness. LG techs say the panel is at fault. I'm wondering if some other assembly or connection in the set could cause this problem.
  • CyberNinja
    Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
    by CyberNinja
    First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
    01-10-2021, 09:38 PM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
  • theo321
    Horizontal black lines on screen - please for your help
    by theo321
    Hello Everyone
    I need your help to repair my poor Samsung TV which decided not to let me watch my favorites series in the afternoon. Suddenly black horizontal lines appeared on the screen making my life a hell
    Photo:
    https://ibb.co/Kyhm9M5
    Close up photo:
    https://ibb.co/zNtv4XP
    I have seen many youtube videos with guys who put a tape in ribbon cable and TV fixed in a magic way (I have tried without success).
    My TV model is: LE46C750R2W
    Photo:
    https://ibb.co/Q6RFN94
    I have tried to disconnect one...
    06-19-2023, 04:28 AM
  • Firentiosi
    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
    by Firentiosi
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the...
    11-27-2024, 12:33 AM
  • Raulnn
    Sony KDL-50W685A horizontal black lines Pattern
    by Raulnn
    good morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.
    12-10-2023, 06:50 AM
