alba lcd42880f
  • newtothis
    • Mar 2013
    • 1556
    • england
    alba lcd42880f
    Well bought a non working alba 42 inch tv that had signs of a bad psu, TV wouldn't start up, stuck in standby.
    Opened the tv up and indeed the PSU was bad.. Another vestel! Replaced 2 caps and a diode and voila the psu was up and running again...
    Problem... Once the tv started there were horizontal lines flickering and 2 solid 1px lines vertically... Well instantly knew that's a bad LCD panel.... Stripped the tv and inspected Tcon connections then across the ribbon cables for the LCD... after prodding 2 of the ribbons the lines flickered and changed... No chance of repair to the cables so I have a dead LCD.
    Now my question, how can I find what other TV sets use this same LCD panel? I cannot find a part number for the panel anywhere and will be a lot easier to find a replacement panel from a doner set if there are other makes I can use with it.
    Re: alba lcd42880f
    Check the model # of panel - e.g. SAMSUNG LTA4088ABCDEF - and use that for replacement, but is it really worth it for a bargain basement Vestel?
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: alba lcd42880f
      Depends how cheap I get the donar for... Only paid 5 quid for the TV
        Re: alba lcd42880f
        Personally I'd sell the TV with the defect. Should be able to get £100 or so like that.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Re: alba lcd42880f
          After switching it on again one entire column has gone... So that ribbon has completely given out.
          Don't think I'd stand a chance of getting rid of it for £100
            Re: alba lcd42880f
            Is it on edge of screen or in middle? Who made LCD panel in this set? Samsung, AUO, LG Display, Chi Mei, Chungwha...?
            • newtothis
              • Mar 2013
              • 1556
              • england
              Re: alba lcd42880f
              its the second column off the right hand driver board.... so about 4 inches in.
              Cant find any identification marks on the panel
                Re: alba lcd42880f
                Can you post a picture of any stickers on the back of the panel? Just so we can track which panels are failing early. I've had a similar thing happen to me with a Samsung 32" LCD.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Re: alba lcd42880f
                  The Panel is an LG LD420WUN-SBA1
                  Could someone try finding what other sets use this panel please?
                  I can't seem to find any info.
                  • learnmore
                    Samsung UE70TU7020K Which lines to tape on a bad panel
                    by learnmore
                    Hello Community,
                    I'm working on a Samsung UE70TU7020K.
                    It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
                    I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
                    03-15-2024, 03:01 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • Anonmis
                    Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                    by Anonmis
                    Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                    The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                    12-01-2023, 04:31 PM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
                  • Raulnn
                    Xiaomi L55M5-5ASP fine lines on the panel uniform
                    by Raulnn
                    Good afternoon! Does anyone know how to remove these lines? They are very fine lines at the bottom of the panel. I have 2 identical panels, and I have even thought that this brand has this lattice format, although I highly doubt it.
                    The photo from the YouTube app is where it is best seen.
                    thanks in advance....
                    01-28-2024, 10:30 AM
