VIZIO VX37L will not scan Digital channels or respond to up/dn channel changes
    • 12276
    • U.S.
    Re: VIZIO VX37L will not scan Digital channels or respond to up/dn channel changes
    Something to try: double re-scan which means disconnecting the coax input then doing a complete channel scan on the “cable” input with the coax disconnected. After that completes, re-connect the coax and do the scan on “cable” input a second time with the coax remaining connected this time.
    • dicky96
      Hitachi V19B01922 Channel Tune problem
      by dicky96
      Hi Guys
      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
      He also has an LG TV, so three screens in the bar
      I installed three Satlink ST-6503 DVB-T Modulators
      This model https://www.aliexpress.com/item/32916553905.html
      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
      02-09-2023, 09:20 AM
    • rustinjust
      Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
      by rustinjust
      My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
      The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
      It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
      I have to turn the tv off and then on again with...
      09-28-2023, 12:23 PM
    • BOSCHNJAK
      by BOSCHNJAK
      ABOUT ME INTRODUCTION FILE
      2
      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
      2022 BEV, PROJECT ?
      2021 BEV, PROJECT ?
      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
      12-28-2023, 02:09 PM
    • dicky96
      I need to block a UHF channel but not sure how to do it
      by dicky96
      Hi guys
      I couldn't really find a section on the forum for this question so I guess I will put it here
      I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
      Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
      Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
      Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained...
      01-31-2022, 05:24 AM
    • sima112
      Marantz pm 6005 right channel not worknig
      by sima112
      Hi guys,
      I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
      01-30-2023, 12:11 PM
