Samsung LN40B500P3F with an odd problem
+ More Options
Posts
    Re: Samsung LN40B500P3F with an odd problem
    Here the test for check the winding resistance, they should be how they are setup for the pin outs, set meter to 2K OHMS scale. There are two set of high voltage windings on each transformer.
    • baitism
      • Apr 2013
      • 43
      1.5-1.6 for all of them.
      • baitism
        • Apr 2013
        • 43
        I have an extra power board. Should I try swapping out some of the transformers?
          I would swap the entire board myself though it doesn't look like any transformers are bad.
          • baitism
            • Apr 2013
            • 43
            I ordered a new board. The other one I have is some junk one the guy ordered from Hong Kong that came with busted capacitors. In the meantime, I would like to learn more about troubleshooting power supplies down to the component. Is there a good website to learn about that kind of stuff?
            • baitism
              • Apr 2013
              • 43
              New PS board fixed it. Thanks for the help tom and bud!
                Glad to hear! Did you do the xformer's resistance reading on the new board?
                  09-07-2024, 05:50 AM
                • howardc64
                  Samsung UN55JU650DF network/streaming problem
                  by howardc64
                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                  07-09-2025, 12:44 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
