Samsung LN40B500P3F with an odd problem
  • baitism
    • Apr 2013
    • 43
    I bought this from a guy who tried to fix it by ordering a new PS/inverter board from Hong Kong. The board they sent him was all effed up so he gave up.
    Here is the weird thing. When I plug in the power supply it seems to run alright. Some of the voltages are a little low, though. However, when I plug it into the tv, the backlight comes on just for a split second and then goes off; the tv is always unresponsive. I also noticed that the pins that attach to the cable that runs to the main board don't received voltage when it is plugged into the tv, but do when it is not plugged in.
    I am kind of at a crossroads for what to do. The four main capacitors that usually fail all test well.
    The sloppy soldering job was the sellers...
  • baitism
    • Apr 2013
    • 43
    Re: Samsung LN40B500P3F with an odd problem
    Update: I put this on the back burner for awhile, but I am back to it with some new info.
    The power supply tests out fine by itself. However, when it is plugged in the LCD panel it does not. What could possibly cause that? A short somewhere or is there a component farther down the line malfunctioning? Thanks.
      Check the voltage across the large 450V capacitors both in standby and when powered up.
      • baitism
        • Apr 2013
        • 43
        Alright Tom. I will try that. I am using this thread, too https://www.badcaps.net/forum/showthread.php?t=19681 because it seems like it could be a similar problem.
        • baitism
          • Apr 2013
          • 43
          So I am getting ~66 volts on the two large ones. Here is the odd part. For the first time ever, I plugged it in and the backlight stayed on (I had it disconnected from the main board), but I moved it a couple inches and it went back off. So, the back light functionally works.
            What are you using for the ground point when you measure that voltage with your meter?
            "I plugged it in and the backlight stayed on (I had it disconnected from the main board)" That is how you verify if the power supply/inverter board is working or not on this chassis by disconnecting the wires going to the main board. So it looks like the main board is not sending the BL_ON to turn on the backlights. The backlights should come on and stay on when the TV is plugged in, if it goes off then it is not working.
            • baitism
              • Apr 2013
              • 43
              Metal workbench I have. I got the backlight to come on briefly again. Transformer pulling to much voltage, perhaps?
                Measure across them: red one end, black the other. Only need to measure one, they are in parallel.
                • baitism
                  • Apr 2013
                  • 43
                  I just did that. Is it abnormal for the volts to jump around a lot. As in, I couldn't get a consistent reading.
                    Batteries are good for the meter?
                    By the way, when work in the primary side of the circuit, do not use Safety ground/ or chassis as the Ground ref point, the ground ref point for the primary circuit is the negative leg of the large filter cap.
                    • baitism
                      • Apr 2013
                      • 43
                      161. I was on AC. Will all these be DC?
                        DC for those caps. 161V on DC?
                        • baitism
                          • Apr 2013
                          • 43
                          Yeah. I just redid it and got 163v DC. Also, in the limited time I had to test them before the backlight went off, I checked all the transformers and one of them isn't giving me a consistent reading. Those should be checked on AC, correct?
                          On a side note, is there a diagram or instruction sheet that tells someone fairly new to troubleshooting this stuff where to test for AC and where for DC? Thanks.
                            The voltage on the caps should be over 300VDC when powered up.
                            • baitism
                              • Apr 2013
                              • 43
                              Update! With the backlight on, the caps read ~390VDC. When the backlight turns off it drops to ~160VDC.
                              I have noticed the transformer shown below seems to have inconsistent voltage readings. Could that be causing the panel to shut down?
                              • baitism
                                • Apr 2013
                                • 43
                                To further expand. From top to bottom, the transformers read:
                                With the backlight on: 2VAC, 2VAC, 4VAC, Inconsistent reading
                                After the backlight shuts off they all read ~2VAC.
                                So is the culprit the 3rd or 4th transformer, or none of the above. I feel this is where the problem lies, but I am no expert.
                                  You cannot use the typical low voltage AC meter to read the high voltage output of the inverter transformers, it puts out up to 2000VAC or more at start up and drop down to 800~1000V when they stay on, the frequency is about 70~100KHz which way too high for your meter to read. I hope your meter input circuits did not get damaged when you try to read the output of the inverter transformers.
                                  You need to check the resistance of the high voltage winding of the transformers, no power to the TV of course.
                                    You shouldn't test such a transformer with a DMM while energised. Your meter may have been damaged by the high voltage.
                                    • baitism
                                      • Apr 2013
                                      • 43
                                      Where are the windings? Thanks.
                                        On the bottom of the board, clockwise, the first two are probably one secondary, second two other secondary and the final two on the other side will be the primary.
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          Yesterday, 12:44 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
