Magnavox 30MF200V/17 Won't Power Up
    Re: Magnavox 30MF200V/17 Won't Power Up
    Is there a detailed schematic available?
    • kevinm34232
      • May 2012
      • 1884
      Yep you have it
        Great... Resistor 3544, and capacitor 2544 join at one point. At their mid point please measure the voltage there. If less than 5V, indicates a fault which will cut the relay out.
        • kevinm34232
          • May 2012
          • 1884
          Got 5.3V there
            OK, now between 3560 and 3561. Should be around 0.7V there, possibly a little more.
            • kevinm34232
              • May 2012
              • 1884
              Do you mean 7560 and 3561? If so, 0.73V.
                7560 and 3560 are meeting at the same node so that's fine.
                OK, now check pin #1 of 1305.
                • kevinm34232
                  • May 2012
                  • 1884
                  Thats 5-5.2V
                  • kevinm34232
                    • May 2012
                    • 1884
                    What pages are you on so I can follow you?
                      Did you hold those previous readings through power up and relay click off to see if they change? From those readings, the relay should stay on. So either the relay is faulty (rare), there is a loose/weak connector/solder joint (vaguely plausible) or something else is wrong (not sure what.)
                      • kevinm34232
                        • May 2012
                        • 1884
                        Yes those last readings you asked for all are steady until click off and pin 1 of 1305 is around 5.3v until click off then hangs at just under 5v.
                        What about the 400V line in the schematic that is around 315V is that low? Am I missing something further upstream?
                          But you DO see a drop in voltages at the moment of the click?
                          • kevinm34232
                            • May 2012
                            • 1884
                            Really only after the click
                              The click can only occur if one of those voltages drops so it will occur momentarily before the click. I have had a power-down fault like this before. It's not easy to track down without a 2 channel digital scope: with just a DMM, you're left wondering if the voltage dropped out because the SMPS shut off or the SMPS dropped out because the voltage dropped out. You could be talking about a few hundred milliseconds between the events.
                              • kevinm34232
                                • May 2012
                                • 1884
                                I see. If you had to guess would it be the main PS board or the standby board? It's time I get a nice scope I think..
                                  I would be focusing on the standby PS, on part of that shutdown circuit.
                                  Rigol DS1052/DS1102E is a good scope for around $300.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    I can try getting that board (not too expensive), but I'm concerned with the 400V line being around only 315V, is that something that could cause it to shut down too?
                                      Is that line 160/170V in standby?
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Its 85V in standby
                                          Wow, 85VDC right at the filter cap's legs?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
