Toshiba 32in LCD lines on screen
  • bjorkson
    • Apr 2012
    • 127
    Hi, anyone encounter this on a 32in Toshiba 32AV502R LCD TV? As you can see from the picture, 75% of the screen has these white lines from the bottom to near the top of the screen. Picture still comes through. Possible bad enverter or T-con?
  • bjorkson
    • Apr 2012
    • 127
    Re: Toshiba 32in LCD lines on screen
    So, does anyone have any suggestion?
      I am going to say panel, possibly tab bonding.
      • bjorkson
        • Apr 2012
        • 127
        So, is it fixable? I noticed the screen where the white image appreared will go dark and black out also. Is that a sign of a bad panel? Or possible T-con board?
          Maybe, maybe not. Can't tell for sure, but it looks more like panel than t-con to me. Many videos on youtube about tab bond repairs...
          • bjorkson
            • Apr 2012
            • 127
            Ok, I check it out, thanks Tom for your help again!
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • jeyoung12
              Samsung QN50Q60t lines on screen
              by jeyoung12
              Hi all
              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
              So....i don't know what end of the C ribbon to work with...
              02-26-2024, 10:38 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
              09-06-2024, 05:27 AM
            • kdaniel
              Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
              by kdaniel
              As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
              There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
              After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
              Left...
              11-16-2022, 09:23 AM
