Samsung 32" LCD TV 15 seconds to black LE32A336J1D
  • SuperSkippy
    • Nov 2012
    • 58
    I'm trying to fix this 32" LCD TV. The symptoms are that the TV comes on for about 15 seconds then it shuts down. Once it has shutdown it turns itself back on, and it just goes round in a loop of being on for 15 seconds then shutting down after that.
    When it is on, you can use the buttons on the side of the TV to change the channel, change the volume, change the input, access the menus and so on.
    All the colours are bad when the TV is on- there seems to be not enough red perhaps? Everything looks strange. If you have it on analogue tuning, the snow looks like black and white snow though.
    Internally, the power supply appears to be good- it is putting out all the right voltages. The backlights seem fine. So I suspect the T-Con (strongly), or a bad panel or a bad main board. I've checked the voltage regulators I can find on the main board and they seem to be putting out sensible voltages (a 3.3V, a 1.6V and an 8V from an adjustable one).
    Any tips on how I can narrow it down more than this?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Samsung 32" LCD TV 15 seconds to black LE32A336J1D
    eeprom corrupt maybe?
    • 1supertech
      • Apr 2012
      • 384
      Just a wild guess are you using a surge protector I have read that a surge can corrupt an eeprom.
      • notallbad
        • Oct 2012
        • 1190
        What happens when you power up the tv with the T-con disconnected from the SSB?
        Also, is the PS b/d still outputting voltages when the Tv 'appears' to be power cycling?
          Check ON/OFF or BLON pin is stable.
          • SuperSkippy
            • Nov 2012
            • 58
            That's the main board, right?
            Same- backlights fire, then go out after 15 seconds. repeat.
            • SuperSkippy
              • Nov 2012
              • 58
              It's not my TV, I bought in this state.
              • SuperSkippy
                • Nov 2012
                • 58
                What happens is the backlights go out, then the power drops from 24v down to 0, then the TV goes on again and the 24v comes back.
                • SuperSkippy
                  • Nov 2012
                  • 58
                  The backlight on/off pin is always 5 and a bit volts unchanging whilst the lights are on.
                  If you meant the PSU on off pin (like PS_ON) I've not managed to find that.
                    09-07-2024, 05:50 AM
                  • eigma
                    Samsung UN40H5003 boot loop every ~8 seconds
                    by eigma
                    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                    Main board: BN94-07592P / BN97-08922R...
                    11-20-2024, 10:31 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                    09-06-2024, 11:40 PM
