Olevia LCD HDtv 242-S11 will not turn on.
  • helpme56
    • Jun 2013
    • United States of America
    Input: 100-240v-60150Hz 2.5A ( MAX)
    I am not technically inclined in any capacity so I have no idea what to put here but this is what I found and this is the model number of this television.
    We have been having troubles with this tv for a while now over the last week and a half actually.
    We got this tv back in 2007 and have barely if ever had any problems with it until now that is.
    A week ago it started behaving strangely as in not responding correctly the volume on the tv kept cutting out and it was an act of congress to get it back each time.
    Now this morning my mom tried to turn it on and it wouldnt budge we tried a few things and the blue light blinked really quickly and went off and it still refused to turn on no matter how much we tried to get to work.
    I dont know anything about the capacitors whats inside etc... so please bare with me and talk slowly so I can understand please lol
    As I said I am not technically inclined in any capacity unfortunately.
    If anyone can help me id truly appreciate it please help me find a way to get it to work or at least give me an idea as to what we can do if we cant fix this.
    We have had it unplugged a bit and kept plugging it back in weve been following a few ideas we found online but none of them worked.
    Ty for taking the time to read this have a nice day all.
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
  • robante15
    Acer Aspire 4520 won't turn on after reboot
    by robante15
    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
    If I remove the...
    04-06-2024, 06:50 PM
  • masoksian
    Dell latitude e7470 not turn on .power buton on off and Run Power problem
    by masoksian
    I am dealing with the problem of turning on and off my Dell e7470 notebook.
    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
    The system does not turn on, there is no post.
    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
    The problem continues in the same way.
    I tried to turn on the Fn key, nothing came to the screen....
    02-15-2025, 12:08 PM
  • dqtech
    lenovo x240 nm-a091 wont turn on
    by dqtech
    i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
    board number VIUX1 NM-A091 REV:1.0...
    02-07-2024, 01:57 AM
