Bush BPDP42HD
  • sordids999
    • May 2013
    • 2151
    Bush BPDP42HD
    colours distorted bottom right hand corner of the screen
    any ideas guys ?
    Re: Bush BPDP42HD
    Check Vs, -Vsc, Ve and Va match panel specification.
    • sordids999
      • May 2013
      • 2151
      Re: Bush BPDP42HD
      how do i check tom ?
        Re: Bush BPDP42HD
        Pictures of the chassis layout need be provided first.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • maleksa
          Yamaha MOX8 boot freeze and distorted sound
          by maleksa
          My Yamaha MOX8 synthesizer recently developed two issues.
          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
          11-07-2024, 03:28 AM
        • tyler123456
          Need help identifying an IC chip on a Bush DAB radio (BD-1801)
          by tyler123456
          Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
          I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
          I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
          Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
          Anyone...
          08-16-2024, 12:51 PM
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
        • tuner2000i
          Philips 65PUS8518/12 distorted image after main board replacement
          by tuner2000i
          hello everyone,
          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
          07-15-2025, 01:15 PM
