Magnavox 42MF230A/37 intermitent and Red horizontal lines
    High, new member here. I love to tinker before I throw out my electronics.
    I have saved many a washer/dryer/dishwasher and computer with an inexpensive component change instead of the junk heap.
    When I found you guys, my spirits lifted because I have never tried to fix a plasma TV before.
    I have a 2006 Magnavox 42MF230A/37 Plasma TV. I think I have two separate problems:
    1) There is a red/green/blue horizontal pixel band on the top 5" of the TV. Below it the TV picture is fine. This has been going on for a few weeks now.
    2) Using an HDMI/DVI cable from my cable box to DVI input on the Plasma, the picture including the pixel band with completely cut out for 5-10 seconds and come back on and appear normal.
    I switched inputs to the side yellow RCA, and the picture no longer cuts out. I haven't had a chance to try the component inputs yet.
    I opened up the back to expose the boards. The is no burnt smell or components that I can see; neither are there any puffed capacitors.
    Any help would be appreciated.
    I know it's 7 years old, but if it could be fixed for ~$150, the tinker factor would be priceless.
    Re: Magnavox 42MF230A/37 intermitent and Red horizontal lines
    Can we see a picture of the fault? I have suspicion that it is a Y-buffer fault.
      I'll takes some and get back... thanks
        Here is a shot of the back, full screen and close up.
          Definitely a Y-buffer fault then. How's your soldering, or would you prefer to replace the faulty board instead?
            I've done plenty of component level repairs.
            How easy is it to diagnose?
              Along the left hand side of that picture, you have a long board which connects to the orange/brown connectors which ultimately go to the plasma panel's glass. There is an IC under each heatsink next to the connectors. Replace the top two ICs (~TQFP128 soldering.)
              No diagnosis necessary -- unless you want to narrow down exactly which chip is causing the fault (only one is failed, but due to how they are interlaced, it is hard to tell which.)
                I think things went from bad to worse. I turned it on to check some voltages, and there was a loud pop and the whole screen went black. Any ideas before I throw in the towel?
                  It's quite possible that Y-buffer chip that was failing has failed completely. Unplug the top Y-buffer and see if you get an image on the lower half of the display.
                    I tried disconnecting the top 2, 3, and 4 buffer connectors...nothing changed.
                    I tried HDMI input on main board and RCA input on side board...only black screen.
                    I cycled through all the source inputs, but nothing showed up on the screen, not even the no source box that usually appears when I have the wrong input selected.
                    The only thing different is that the lines that were on top of the screen are now flashing on the bottom 5" of the screen.
                    I looked again, and I couldn't find any burn marks of puffed caps.
                    I'm going for a new TV today, but I will keep trying to fix this one until you:
                    1) either say that we found it and it's fixable
                    2) the parts cost more than $150
                    3) you've had enough
                    I appreciate your help no matter what. Either way, let me know where the beer fund button is, so I can contribute...
                      I meant the whole board should come out of the set. Do you have screen glow in a dark room?
                      Re. New TV, avoid Samsung :P. (This is basically a Samsung PDP inside.)
