Viewsonic VX2255WMB Broken - Need some guidance
  • americanmarten
    • May 2013
    Hey, new here, first post, like what I see so thought I'd drop a line. It is a little overwhelming the info here but it does keep me optimistic about reviving my old monitor.
    I have the same symptoms as this thread https://www.badcaps.net/forum/showth...ghlight=9973gh
    My monitor is the same and the board looks same as in the pics there.
    The power blue LED goes on, screen flashes grey/white? for a millisecond it is so fast hard to tell if the whole screen is that colour. Then the LED power light goes to red after 2-5 seconds, some times longer, but usually 2-5.
    I opened up the LCD after reading the bad caps thread here https://www.badcaps.net/forum/showth...087#post317087
    and replaced two caps that were bulged, the other caps looked fine.
    Symptoms still exist.
    Conducted flashlight test (after cap repair) and I can see images on the screen and they change when refreshed, however, screen is not lit up at all.
    In the other threads, they were successful in replacing the fuses, that is my next step unless some one can see an error in my actions above.
    My questions after measuring with my multimeter the two fuses, (my multimeter does not have a continuity beep setting, the instructions say to use the 2000Ω setting)
    - the P F200 SMD fuse read 1 on the meter, I reversed the probes and got several random flashing high numbers and then a 1
    - the Y F101 fuse read a 003-001 on the meter, I reversed the probes and got 002-001, the longer I held the probe the lower it got till reaching 001 (5 seconds total)
    1. I am thinking that the P F200 fuse is shot and needs replacing?
    2. I am thinking that the Y F101 fuse is ok?
    3. I am thinking that the P F200 fuse controls the lamps to light up the dark images I see with the flashlight?
    4. The bulged capacitors are the cause of the fuse blowing?
    I am quite confused as how to order/pick out a new fuse from digikey, can some one help me with that or is there another website?
    Any thoughts and/or corrections to my thinking, please let me know
    Martin
  • americanmarten
    • May 2013
    Re: Viewsonic VX2255WMB Broken - Need some guidance
    Update: after further research this afternoon, I noticed in another thread to test the transistors, I was not exactly sure what pins to connect so I tried multiple combinations.
    I connected black probe to the upper left pin and the red probe to the bottom flat lip type pin and then to the middle unattached upper pin and then to the upper right pin, all readings of 1, I reversed the red and black probe and did the same, all readings of 1,
    this taken at 2000Ω
    Conclusion: the transistors are fried too? Where to buy and how do I know exactly which ones to get?
    Martin
    • retiredcaps
      • Apr 2010
      • 9271
      My 2 seconds to black guide starting with post #19 (see sig file below) has procedures on how to test and interpret your multimeter results.
      Feedback from people who use digikey is excellent. They have live support people (using phone or chat) who are extremely helpful and can help you find the correct parts.
      --- begin sig file ---
      --- end sig file ---
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
