Samsung SmartTV 3D Strange Patterns, HELP!!
+ More Options
Posts
  • rikrikrik13
    • May 2013
    • 44
    Hi, Im new in this forum. Sorry for my english, its not the best and Ill hope eveyone will understand me.
    I got this Samsung 46'' 1080P 3D Smart tv not working properly Model : UN46D6500VF The tv was made in 2011 so not that old.
    I opened up and I cant see nothing wrong in it, capacitors seems fine, fuse on the t-con seems ok.
    When you start the tv the image as less pattern then when its heat up. I dont want to change all the boards if its a Panel problem.
    When I touch or bent the panel, theres no difference in the lines, also the lines are not always at the same place.
    Everything seems to work properly except for the lines.
    Help ME
    Re: Samsung SmartTV 3D Strange Patterns, HELP!!
    I'm going to say bad LCD panel - possibly tab bonds.
    • rikrikrik13
      • May 2013
      • 44
      I just tried to move all the tabs and there's no change on the screen
        We had one user with this problem recently and he eventually got it to work -- one particular tab very sensitive. Other things it could be are bad T-con with VGH, VGL voltage bad. If you post a picture of the T-con we can indicate where to test for those voltages.
        • rikrikrik13
          • May 2013
          • 44
          Thanks for your reply.
          Here's a picture of the T-con board
            Is there any way you could get closer and get a higher resolution, it's hard to see the lettering near the components and that is what I am looking for. If necessary break the photo into four or more parts.
            • rikrikrik13
              • May 2013
              • 44
              I splitted it in 2, if you need in 4 tell me :p thanks
                I found a clearer pic on ShopJimmy, I needed to see the VONE and VOFFE (VON/VOFF.)
                So, put your meter on DC 200V or DC V, black probe on chassis, red probe on each test point.
                VONE should be around 18 to 25V.
                VOFFE should be around -5 to -15V.
                • rikrikrik13
                  • May 2013
                  • 44
                  Voffe = -12v
                  vone = 32v
                    Von seems much too high. Can you see a point marked AVDD? What does that measure?
                    • rikrikrik13
                      • May 2013
                      • 44
                      Sorry for the late reply, avdd = 17.2V
                        Can you verify your multimeter battery is good. Perhaps swap it. Low battery can cause high readings. AVDD of 17.2V is quite high, it's typically no higher than 15V.
                        • rikrikrik13
                          • May 2013
                          • 44
                          I took another multimeter and i got the same readings
                            OK. It does look like there is a problem with the T-con, with the very high VON and AVDD. I'm not 100% (80% in my opinion), but it's probably worth a punt, if the board isn't too expensive. There's the chance it's a tab bond issue, or a panel issue, which is fairly common with Samsung LCDs.
                            • rikrikrik13
                              • May 2013
                              • 44
                              thanks for your help, I will try to find the t-con and Ill let you know!!
                              • rikrikrik13
                                • May 2013
                                • 44
                                T-Con Board is pretty expensive, almost 100$ with shipping to canada. I think Ill not take the chance and scrap it :p
                                  Nice TV though, stick it on Craiglist/whatever-listing-site for $50 and it'll be gone in a couple of hours, someone will be prepared to repair it.
                                  Please do not throw it in the trash, so many electronics are destroyed with easy to repair faults.
                                  • cashkennedy
                                    • Aug 2011
                                    • 668
                                    That is easily a $300 dollar tv used , lots of us would love to repair that if we lived in your city so we could resell it for profit, list it on craigslist / or keep your eyes out on ebay, a tcon might get listed for 50 tomorrow.
                                    Did you check both ebay and shopjimmy to see if there are any cheaper tcons (has to be the identical part number)
                                    http://www.ebay.com/itm/Samsung-BN95...#ht_526wt_1083 this one is $88. I often offer sellers 20% lower and tell them ill just send the money via paypal (no ebay ending fee) , that is against the terms of ebay, so you cant word it exactly like that. Every seller ive ever asked is like "sure ill relist it now" ... So i would recomend offering them $65 for it if youd be willing to invest that.
                                    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                                    • a3otry
                                      • 7
                                      • canada
                                      hi, rather than start a new post i think it is better to ask my question here
                                      i got a un46d6500vf tv
                                      my vone is 4v, voff no reading
                                      and i eard clicking sound on the tcon
                                      im pretty sure it is not normal but i just want to be sure before i by another tcon for nothing...
                                      thanks eric from quebec
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        well do you have a picture? What's the screen look like? I'm going to say that that's not normal and I had a 32 inch version of that TV comes through one day with the t-con board clicking. Turned out to be a bad t-con. Tried disconnecting the ribbons going from the t-con to the panel. do you still hear the ticking sound coming out of the tcon?
                                        if so replace t-con board
                                          09-07-2024, 05:50 AM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
                                          09-06-2024, 11:40 PM
