Samsung SmartTV 3D Strange Patterns, HELP!!
  • nomoresonys
    • 12276
    • U.S.
    #41
    Re: Samsung SmartTV 3D Strange Patterns, HELP!!
    May have a damaged cable??
    • budwich
      • Jul 2015
      • 3097
      normally, when a tcon to panel cable is disconnected, the side which is disconnected displays a "plain white" screen while the other side forms what it can of the picture. Those simple tests are done to check which side might have an issue. In your case, the disconnected side is dark while the other side has significant issues. You should start another thread if you want to do more investigation.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4458
        • Italy - Milan
        #43
        what makes the two issues different?
        This for example:
        At first there was a large white vertical strip of stuck pixels about 1/4th of the screen wide
        and the thing you had very low readings on testpoints, now if you see a picture on half screen then your TP readings cannot be the ones you write, so you made jam with cables in the meantime
        My screen started out looking just like the OPs with a full image
        this you are writing now, but you might be specify this earlier, it's not clear how you could have become to the point above, for your info my guess about the OP's defect is bad processor soldering on mainboard, so if i'm right, your position now is to have a severe damage to mainboard and to panel, so i think is not worth forther tries.. sorry
          09-07-2024, 05:50 AM
        • Rubenlily
          Samsung QE50Q67TAU - horizontal lines
          by Rubenlily
          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
          I'm no expert but I've done the tape...
          08-16-2023, 01:12 PM
        • jeyoung12
          Samsung QN50Q60t lines on screen
          by jeyoung12
          Hi all
          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
          So....i don't know what end of the C ribbon to work with...
          02-26-2024, 10:38 AM
          09-06-2024, 11:40 PM
