Dell W4200HD salvaged!
  • crbn79
    • Feb 2011
    • 64
    I got my hands on a 42 inch dell plasma today. The previous owner claimed it would power off on it's own. Since the glass was in good shape and a picture came on I gladly met the owners request for $20.
    Once I got it home I found a 450v 33uf cap which looked odd. Once I pulled the board I realized the positive leg was broken on this cap and it was just barely making a connection. There was also about 1/4 inch of dust on everything inside the TV.
    After a good cleaning I decided to go ahead and pull the cap and I discovered there was plenty of leg left that i could solder it back on. Unfortunately I already ordered a replacement, but I can always use it on another TV.
    I've left the TV looping Metallica's Black Album for 4 hours now with no shutdowns!
    I was surprised to find that Samsung decided to skip the speakers on this TV. However I was able to splice in a set from a Donor TV and hide them under the back cover.
    To date, this is my best repair, only $20 and a little gas invested!
    Re: Dell W4200HD salvaged!
    Nice one!
    Note: TV may use a Samsung panel, but it is made by Dell's OEM, who supply the motherboard, case, remote, stand, etc. and assemble the whole lot into one package.
    Careful with burn in -- it is a plasma after all...
    • crbn79
      • Feb 2011
      • 64
      Originally posted by tom66
      Nice one!
      Thanks Tom66, I have used quite a few of your posts, faqs and guides to get a couple rolling including this one.
      As for the burn-in, I made sure to have the screen saver going in full screen while I tested it.
      I've had it hanging in my basement hobby room for a few days, streamed a couple of movies to it while I repaired other things and it has done GREAT! No issues what so ever.
      I can't wait till I get my 50inch project plasma finished to replace it!
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • SurrealMustard
        What parts can be salvaged from a plasma with a damaged display panel?
        by SurrealMustard
        I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
        03-09-2025, 08:29 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
