Green line on Panasonic 42" Plasma
  • Rben
    • Apr 2013
    • Uk
    Hi guys. Hoping for some advice. I've a Panasonic Viera TX42U20B Plasma television. Over the last week I've noticed a green line, or more specifically what looks like faint green outline rectangles down the centre of the screen. It's most usually visible in face shots. Some may not even notice it, but now I know it is there I find it annoying. Does anyone have an idea what may be causing this and is it likely to be fixable?
    Thanks in advance
    Russell
    Re: Green line on Panasonic 42" Plasma
    Can we see a picture of the problem? If it is what I am thinking, it is often just a loose connector.
    • Rben
      • Apr 2013
      • Uk
      Thanks Tom. It's really not easy to see its so faint.Doubt it would show on picture.
      Russell
        Maybe a video? Need to be able to tell you if the panel is bad (not repairable) or if it is the common issue with the connectors. Only being able to see it, picture or video, will I be able to tell you...
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • Eaglecrest
          Panasonic plasma color stripe
          by Eaglecrest
          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
          11-05-2025, 06:16 PM
