Vizio M421VT LED no display
Re: Vizio M421VT LED no display
I still have issues.
I left backlight disconnected (CN902,CN905) when I tested VLED voltage.
After pressing power it was 40vdc. for a second then dropped off.
I had the same results checking voltage with backlight connected.
From BudM-I think once the bridge rectifier is replaced to get the voltage for the LEDs you will be OK unless the circuts that drive the transformer also failed due to shorted out bridge.
What next?Last edited by ryan74; 04-29-2013, 01:26 PM.Comment
So what voltage do you get at the +/- terminal of the bridge, it must be quite high since the filter caps are rated at 33uf 200V.Never stop learning
So, next step is to see if BLON comes on and stays high and also maybe DIM (I am not sure if this set modulates the voltage to vary brightness or uses PWM; it may use a combination of the two.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I pulled and tested bridge just to be sure. Everything tested as below except:
Pin 4 to 1 was .879V.
So, testing the bridge: Looking at device from top label side pin 1 is +, 2 and 3 are ~ and 4 is -.
Meter probes in order (red) (black)
Pin 2 to 1 you should see ~0.4V
Pin 3 to 1 you should see ~0.4V
Pin 1 to 2 you should see OL
Pin 1 to 3 you should see OL
Pin 4 to 1 you should see ~0.4V
Pin 1 to 4 you should see OL
Pin 2 to 3 you should see OL
Pin 3 to 2 you should see OLComment
My error 4-1 is correct as there are two series diodes.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The 40V reading at the output of the bridge seems too low since the filter caps are 200V rating.Never stop learning
I know transformers rarely go bad but could it be a bad transformer or most likely something else?Comment
The capacitors on the output could be bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
or the drive circuit that drives the transformer is not driving it correctly, that is why I wonder if it gets damaged when the bridge shorted out.Never stop learning
I'd be surprised. Most drive circuits fail or work. Like shorted FETs. Won't work. A few exceptions, like bad coupling caps and current shunt resistors, of course.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
when I press power I get the 40v for a split second.
This may sound stupid but I don't know. The drive circuit for transformer- Is this the cold(north) side? or are you refering to the circuit before transformer?
I pulled all 4 caps in upper left of board(2-200v) and tested good.
200v 33uf=35uf
50v 47uf=48uf
Im stuck at this point but I think I found a board for $120 but Im not sure I want to give up yet.Last edited by ryan74; 05-01-2013, 04:45 PM.Comment
The hot side, there are two MOSFETs and little IC for driving them, you can look up the spec of that IC.Never stop learning
I rechecked voltages:
on/off-4.91v
dim - 2.93v
12v - 11.91v
12v - 11.91v
G
G
G
24v - 24.67v
24v - 24.67v
ps_on-3.09v
5.2v - 5.11v
5.2v - 5.11v
acd -
Vled-194.7mV
all #- 10.65v
Vsync- 25mV
DIM- 58.5mV
G
DCLK- 49.1mV
G
I assume vsync and dim should be giving a reading and im not sure about ACD.
Now im thinking it is the middle board(pc/tcon?) or possibly main board.
http://www.shopjimmy.com/vizio-cbpft...2-pc-board.htm
these are the original readings from old board:
1)BL_on = 4.91V
2)BL_DIM = 2.93V
3)12V. = 12V
4)12V. = 12V
5)G = 20mV
6)G = 20mV
7)G = 20mV
8)24V. = 24.73V
9)24V. = 24.73V
10)BS_on = 3.09V
11)5V. = 5.09V
12)5V. = 5.09V
13)PWR_ok = 2.8mV
CN902
Vled = 235.6mV
#4-1 = 10.69V
#4-2 = 10.27V
#4-3 = 10.67V
#3-3 = 10.65V
#3-2 = 10.66V
#3-1 = 10.64V
Vled = 236.2mV
Cn905
Vled = 237mV
#2-1 = 10.25V
#2-2 = 10.63V
#2-3 = 10.64V
#1-3 = 10.66V
#1-2 = 10.27V
#1-1 = 10.67V
Vled = 237.0mV
Any idea how to test pc board? Theres a connector from main board but nothing listed by it.Last edited by ryan74; 05-13-2013, 01:21 PM.Comment
Assuming...7 Photos -
This specification for the Acer Spin SP313-51N-509V Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP313-51N-509V boardview and SP313-51N-509V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 11:20 PM
This specification for the Acer ENDURO EN715-51W-509V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EN715-51W-509V boardview and EN715-51W-509V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 10:00 PM
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... - Loading...
