Haier L37A9A-A1 NO POWER
  • s_henya
    • Jan 2011
    • 481
    • Israel
    Re: Haier L37A9A-A1 NO POWER
    more bad news,
    the ic chips arrived. when looked at the psu, i saw a tiny smd transistor broken Q9.
    (had to put the pcb over bouble wrap, big mistake!)
    all that is written is: 2.A 1 ->the 1 is on its side.
    i dont know what to do,
    how can i know its specs.
    • tw2005
      • Oct 2011
      • 6458
      I'm thinking could be one of these, watch out for the different package sizes.
      Could it be the 1 is a "-" One of the NXP sheets has - 2A where - = Hong Kong
      Photo?
      • s_henya
        • Jan 2011
        • 481
        • Israel
        im sure of the writing.
        never swapped such a transistor before, so i dont even know how to search for
        specs.
        added a picture for more reference.
        a schematic would be of help, even if i have to pay for it.
        • tw2005
          • Oct 2011
          • 6458
          I'm confident 2A will be what I posted, but see what everyone else comes back with.
            2N3906 sounds right for a driver transistor. There's no particular performance requirement there.
            • s_henya
              • Jan 2011
              • 481
              • Israel
              #26
              im sorry the one you suggested 2N3906
              is not smd
              any suggestion to smd?
              • tw2005
                • Oct 2011
                • 6458
                is not smd
                What do you think all those datasheets are?
                • s_henya
                  • Jan 2011
                  • 481
                  • Israel
                  #28
                  ok so which one should i order, with this model all i can find
                  is penetrating components
                  • tw2005
                    • Oct 2011
                    • 6458
                    Any MMBT3906 in a SOT23 package. Do you have any old dead boards you could steal from? A chance you will find one otherwise you may have to buy a lot more than you need.
                    http://il.rsdelivers.com/catalogue/s...0883|A-432579| (UK stock)
                    http://www.digikey.co.il/scripts/dks...741&PV16=12624
                    http://www.ebay.com/dsc/i.html?_sadi...6&LH_PrefLoc=2
                    • s_henya
                      • Jan 2011
                      • 481
                      • Israel
                      #30
                      OK i listened to your advice and, looked at my junk boards that i stashed long time ago.
                      found similar transistor 2A 3 on the side. from a pci lan card.
                      should it fit?
                      i think that the are pretty gentle,
                      with temp should i use on the hot air?
                      or should i work with the soldering iron?
                      • tw2005
                        • Oct 2011
                        • 6458
                        I don't have hot air, I use 2 irons and heat all 3 pins at once. If what you found is SMD it should be the same size I expect. Was the location on the board marked as if it was a transistor like Q___ or PQ ___?
                        • s_henya
                          • Jan 2011
                          • 481
                          • Israel
                          #32
                          Q9 as you can see in the pic ive added.
                          (thank you for the tip by the way :-) )
                          • tw2005
                            • Oct 2011
                            • 6458
                            No, on the pci donor board. I just want to be sure it's a transistor and not a diode but if you're sure it's a transistor I'd go with it. The sideways number is just going to be a production stamp, the 2A will be the mark.
                            • s_henya
                              • Jan 2011
                              • 481
                              • Israel
                              #34
                              sorry didnt understood you before ,
                              its Q1 on the pci Card.
                              ill try to find some flux and get it out later tonight or tommorow.
                              hope to come back with good news.
                              • tw2005
                                • Oct 2011
                                • 6458
                                sounds good, hope it works out. adding fresh leaded solder to the pins will help to get it off faster since they use lead free which I dislike.
                                • s_henya
                                  • Jan 2011
                                  • 481
                                  • Israel
                                  #36
                                  finally good news,
                                  replaced both the transistor and ic,
                                  it works!
                                  THANK YOU VERY MUCH!
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                    03-31-2024, 02:12 PM
                                    09-06-2024, 05:59 AM
