Phillips 50PF7521d/12 Wont turn on
  • Johnboy78
    • Apr 2013
    • 60
    • Uk
    Re: Phillips 50PF7521d/12 Wont turn on
    Yes i do want to replace them just cant seem to find the right ones? maybe im looking at the wrong ones. Could you possibly point towards the correct caps if poss? Those 2 are roughly 25x16ml 63v 470uf and 130 degree.
      Sure about 63V 470uF?
      Here is replacement:
      http://www.digikey.com/product-detai...0352-ND/266361
      • Johnboy78
        • Apr 2013
        • 60
        • Uk
        thats 105 degree, i need a 130
          You probably don't. The original capacitors were of poor design and ran hot, so required a higher operating temperature. Generally, 105°C is fine. Acquiring 130°C capacitors is next to impossible. I'm guessing the caps are Samwha? There is a well known manufacturing defect with a batch of them around 2007~2010.
          • Johnboy78
            • Apr 2013
            • 60
            • Uk
            Your right they are sanwah! And that is probably why i cant find the 130 degree ones if as you say its impossible to get them now lol. So what about heat wise if i was going to swap them for 105'c will they still be able to cope? these sanwahs are bigger then normal caps too.
              If the heat inside is hot enough to boil water, I think you have really bad problem in the TV.
              • Johnboy78
                • Apr 2013
                • 60
                • Uk
                #27
                i dont know how hot a tv would get to be honest lol
                • Johnboy78
                  • Apr 2013
                  • 60
                  • Uk
                  #28
                  TV is all sorted now but i still need to change the 2 samwha caps, ive brought sum 16x20ml stubby caps but will these be ok to fit? or would i need taller caps? whats the difference? Thanks
                  • Johnboy78
                    • Apr 2013
                    • 60
                    • Uk
                    #29
                    Anyone?
                      Stubby caps??
                      • Johnboy78
                        • Apr 2013
                        • 60
                        • Uk
                        #31
                        yeah they are like half the size of the gold caps that are in the pic (The samwha ones) but are 105c not the 130c
                          What is the brand/manufacturer and series (usually a letter code e.g. FC, FM) of the capacitor?
                          • Johnboy78
                            • Apr 2013
                            • 60
                            • Uk
                            #33
                            Panasonic FC series 16x20mm EEUFC1J471 - part number. Decided to go with these as ive heard good things about them.
                              They are good and should be fine.
                              • Johnboy78
                                • Apr 2013
                                • 60
                                • Uk
                                #35
                                Thanks Tom ill report back when ive fitted them, hopefully tomorrow! if im not back you know ive blown myself up ha.
                                • vdrokko99
                                  MBP wont turn on Only green light on charger
                                  by vdrokko99
                                  I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                  SMBUS_SMC_BSA_SCL 3.5V
                                  SMBUS_SMC_BSA_SDA 3.5V
                                  12-01-2024, 12:18 PM
                                • jxrepman
                                  Asus X453MA won't turn on and green led light blinking
                                  by jxrepman
                                  Hi there,
                                  I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                  I have checked the charger and it is giving 19+ V
                                  I have disconnected the battery and pressed power button for 30 seconds.
                                  I tried another RAM stick.
                                  Tried disconnecting the keyboard and touchpad.
                                  Tried disconnecting the HDD and the wifi adapter.
                                  The problem persists.
                                  Hope you could help me out on this one. Thank you.
                                  12-14-2024, 06:40 AM
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • DrFalken
                                  MacBook A1342 820-2567: green light but won't turn on
                                  by DrFalken
                                  Hello everybody !
                                  I've a MacBook A1342, M/B 820-2567, that won't turn on.
                                  Magsafe is solid green, when I press power button the fan spin for just half second.
                                  Some readings:
                                  PPBUS_G3H = 12,58V
                                  PP3V3_S5 = 3,3V
                                  PP3V42_G3H = 3,42V
                                  PP1V1R1V05_S5 = 1,05V
                                  PP18V5_G3H = 16,95V
                                  08-26-2023, 02:56 AM
                                • matthewmcconaughey
                                  I need help with my friend Sony GDM-FW900 24” CRT
                                  by matthewmcconaughey
                                  Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                  I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                  1. It started with a bright and greenish picture upon starting a cold monitor.
                                  2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                  05-16-2023, 03:15 PM
