Hi Guys Can You Take A Look At This Pic TH-42PX60U Vertical Lines Panasonic
  • davewilson61
    • 110
    • usa
    hi guys panasonic TH-42Px60U
    vertical lines....they also move around when changing channels
    dont know where to start on this one...no bad looking caps
    thanks dave
    Re: Hi Guys Can You Take A Look At This Pic TH-42PX60U Vertical Lines Panasonic
    The panel is failed and possibly the vertical connections are loose.
    Disconnect and re-seat connections on bottom. POWER MUST BE OFF WHILE DOING THIS.
    • retiredcaps
      • Apr 2010
      • 9271
      Hmm, lots of nice teal colored Rubycons rated at 135C.
      --- begin sig file ---
      --- end sig file ---
        Yes, these plasmas are excellently well made, but sadly suffer from panel failures quite often. I've considered picking a few up, but panel failures are basically the only problem these suffer... too well made otherwise!!
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • lupinIII
          Vertical Lines Panasonic Plasma Th-37PX80
          by lupinIII
          Hello everyone, I've been browsing this forum but I didn't find similar vertical lines like this on Panasonic Plasmas
          So they are not all over the screen but there's lines on both halves of the screen. The lines are also present with no signal, at least some of them but I can't distinguish all of them with no input. With no input the vertical lines on the right side are definitely more visible.
          It started with one line half a year ago, then two and has been increasing the number of lines.
          Where or what could be the problem? What steps should I take?...
          01-12-2020, 08:20 PM
