Bush BPDP42HD2
  • crt man
    • Mar 2013
    • 106
    • England
    Bush BPDP42HD2
    Hi All,
    New to Forum, I wonder if anyone can help me with the above model Plasma.
    It is a Bush in name only and has Samsung everything else,
    This is the first Plasma I have looked at ,done a couple of LCD's
    power supply's , but manly CRT's.
    History bought without picture , Traced fault to short Y buffer taking out Y main and X main.
    Picture back on but everything on screen to the Right programs Menu's Graphics
    Set VA, VSC and VS to spec but no change only thought left Logic board.
    Pictures follow
    Re: Bush BPDP42HD2
    The plasma panel is likely defective. It is a common issue with these Samsung panels.
    • crt man
      • Mar 2013
      • 106
      • England
      Re: Bush BPDP42HD2
      Thanks Tom
      Waste of money then ? Poor lifespan Manufacture date Sept 2011
      Alan
        Re: Bush BPDP42HD2
        Likely that line is what took out the buffer in the first place. Yes newer single-pane-of-glass Samsung panels suffer from this a lot.
        • crt man
          • Mar 2013
          • 106
          • England
          Re: Bush BPDP42HD2
          When I first put it back together, there was a large black bar and about 10 lines underneath it, it looks a lot better now.
          Apart from the central issue.
          Alan.
          • crt man
            • Mar 2013
            • 106
            • England
            Re: Bush BPDP42HD2
            Tom
            Do Samsung LCD's, suffer the same sort of Failures.
            Alan
              Re: Bush BPDP42HD2
              Yes, though typically more vertical lines, their plasmas have horizontal (like yours) and vertical line failures.
              • crt man
                • Mar 2013
                • 106
                • England
                Re: Bush BPDP42HD2
                Hi All
                Update on this TV, fully restored to working order,
                center issue traced to AV board, line issue poor connection.
                  Re: Bush BPDP42HD2
                  That's nice to hear you fixed the line, it's rare to find that to be a loose connection so you got lucky.
                  • Giff1711
                    • Mar 2012
                    • 34
                    • United Kingdom
                    Re: Bush BPDP42HD2
                    Hi
                    Can I ask you when you had your no picture problem where you getting the correct voltage at test points Vs 207. Va 55 ? Its just I have same model & i'm not getting Vs & Va voltage ( when I first turn on it measure correct for a second) The only voltage's i'm getting are the D15v on cn804 & the voltages on cn802 Disconnecting y& z bds does make a differance
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Re: Bush BPDP42HD2
                      I had something similar with a 42B456.....
                      Some dumbo had changed the panel-options in the engineer menu to a 19" LCD!
                      Correcting that, and everything was restored to normal.
                      TELEFIX
                      • tyler123456
                        Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                        by tyler123456
                        Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                        I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                        I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                        Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                        Anyone...
                        08-16-2024, 12:51 PM
                      • ArMaaN376
                        Samsung PS51E550 Plasma TV
                        by ArMaaN376
                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                        Opened TV cover & observed foll
                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                        How to confirm Y -Buffer board...
                        06-19-2024, 04:05 AM
                      • jm1234
                        Panasonic plasma TX-P42ST50 - 6 blinks
                        by jm1234
                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                        I checked that board for any obvious faults...
                        05-22-2024, 06:59 AM
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • chazh
                        LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                        by chazh
                        This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                        I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                        The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                        09-01-2025, 08:56 PM
