Samsung S42AX-YB04 Plasma TV stuck in standby
    Re: Samsung S42AX-YB04 Plasma TV stuck in standby
    No, did any of us say that?
    Check voltage from pin 2 to pin 3. OR voltage across CB808 (one only.)
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      sorry mate :/ il check voltage across pin 2 to 3> black probe on one red on the other ?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        No--Its not that part. You have the STD_5V
        TELEFIX
          The STBY is unstable though.
          Either:
          - the controller is operating in low power mode (and the ripple is normal)
          - or there's a bad startup cap, controller or other issue (and the ripple is abnormal preventing the main board starting properly)
          @mikey Yes that is how to test it.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            --No need to check the volts across CB808, that circuit is working--You have the STD_5V
            (You checked that before--Its in yer list of voltage readings....)
            TELEFIX
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              yeah mate i had the STD5v leading to the Av board but there was no cable in the STD5v leading to the control board
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                #27
                Allegedly--that voltage is varying by only 0.1V--which could have been a user-made error by poor connection of meter probe....
                TELEFIX
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  #28
                  ok i will now test pin 2 to 3 on the 7 legged chip. how do i know which pin is n and 3 ? meaning there is 4 pins on 1 side and 3 on the other so would pins 2 and 3 be the one on the 3 legged side with the space in between them ?
                    Only need to check voltage across CB808. They're electrically the same. What was the result?
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      #30
                      was boucing around a little, held probes straight and firm. but volatges ranged from 15.4 - 17.9
                        The IC requires a min 16V to start up. So it would appear to be OK, but I would be suspicious of it.
                        I would prefer to check the supply with a 22 ohm 2W resistor to see if it regulates better under load. Any chance you can source one? Or a similar value 18~33 ohms minimum 1W (will get hot) but ideally 2W.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          #32
                          no, i can order one from ebay though ? would these suit ?
                          http://www.ebay.co.uk/itm/2W-Metal-F...item20ce8eebfb
                            That would be fine -- Maplin stock them too.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              where would i put that though tom, sorry to sound like a d**khead just new to all this kinda stuff, tryin to learn too much too fast but appreciate the help. i have attached a picture of what CB808 is on the board as it looks different from a resistor >?
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                #35
                                cant seem to find a 22 ohm 2W resistor on maplins website :/
                                  You're putting it across the STBY voltage, not on the primary side. And not as part of a repair, because we still don't know what's wrong -- it's part of a diagnosis.
                                  Check Maplin code W22R. (For tests only.)
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    #37
                                    W22R on maplins site returns 3 Watt Wirewound Resistor would that be correct
                                      Yes. Watts (power dissipation) is a more than or equal rating...
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        #39
                                        will try get one today and give it a try, came across a guy on ebay a few months back when i had to repair a power board on a LG LCD tv, the guy also does cap repair kits for this board including start up caps so is this a common problem with these boards
                                          I'm thinking that; the unsteady voltage makes me suspect that capacitor. However, I want to rule it out (or in) first.
                                            09-07-2024, 05:50 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Ukdigger
                                            Samsung UE46f5000AK Stuck on Standby
                                            by Ukdigger
                                            When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                            PSU number bn44-00610A L46SF_dpn
                                            1 B13v 12.4
                                            3 B13v 12.4
                                            5 Vamp 12.4
                                            7 Vamp 12.4
                                            9 GND...
                                            08-08-2024, 09:17 AM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
                                          • rju
                                            Samsung 60" Plasma TV, Blinking Standby LED
                                            by rju
                                            A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                                            Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                                            Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                                            07-21-2020, 05:23 AM
