Samsung HPT5064 Issue
  • glen4cindy
    • Dec 2012
    • 52
    Hello.
    Have a friend, Samsung HPT5064 50" Plasma TV, started out with a sound no picture issue. His young ones kept power cycling the TV thinking that some "magic" was going to take place and it was going to "fix" itself and suddenly be working.
    Well, now, it is just going thru a series of clicking, but, will not start. No program sound, just this clicking.
    None of the caps on the Power Supply board "look" bad, but, I know this is not a reliable indicator.
    Should we recap the PS and see if we can make the original problem reappear?
    I tried unplugging both Sustain boards from the PS board to see if maybe there was an overload condition on one of those that was making the PS board relays click click click.
    Thanks in advance.
  • martyparish
    • Dec 2012
    • 313
    Re: Samsung HPT5064 Issue
    It sounds like a possible PSU problem. Good close up pictures will help a lot. What brand caps are they?
    • glen4cindy
      • Dec 2012
      • 52
      Will supply when able. Thanks....
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
        09-07-2024, 05:50 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
