Finlux 32FLD760P No picture
  • mitsu79
    • Mar 2013
    • 14
    • Finland
    No picture, sound ok.
    Turns on from standby ok, backlight lids, but no picture, if I try to change channel or go to menu, backlight dims or brightens just a bit.
    This is elderly persons tv and I only have secondhand info about symptons before it went blank: Theres been picture problems from new, color problems, flickering? (not sure and not sure how to say this in english, but maybe, rapid picture movement left to right etc. from time to time). Picture have had lines and blurred unwatchable, before it went totally black.
    Could this be PSU issue and maybe be repaired with PSU repair kit or MB or something else?
    PSU: 17PW20.1
    MB:17MB22-2
    Re: Finlux 32FLD760P No picture
    Very common issue with this PSU.
    Two major known issues:
    - C878/C877 capacitors fail (cheap and easy fix)
    - PFC circuit fail (causes main capacitor voltage to drop from 390V to 320~340V)
    The problem sounds more like C878/C877 personally to me.
    • mitsu79
      • Mar 2013
      • 14
      • Finland
      Thanks, what capacitance should C878/C877 capacitors have?
      • gilly1984
        • Jun 2012
        • 751
        15nf 1600v
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
          I've seen as low as 400V used on these PSUs... I would recommend min 800V replacements.
          • mitsu79
            • Mar 2013
            • 14
            • Finland
            Ok, I'll try to measure them, if my multimeter have heated up over radiator, my garage thermometer says -6 celsius... outside about -20C
            text on capacitors: mmkp82 153j630
            • mitsu79
              • Mar 2013
              • 14
              • Finland
              Both capacitors were 34nF?
                Did you measure them in circuit?
                • mitsu79
                  • Mar 2013
                  • 14
                  • Finland
                  In circuit, yes.
                    Those you need to measure out of circuit.
                    • mitsu79
                      • Mar 2013
                      • 14
                      • Finland
                      Ok, I'll remove and measure them again later today.
                      • mitsu79
                        • Mar 2013
                        • 14
                        • Finland
                        C878/C877 were both 13,7, new ones I got measured 13,9.
                        I think those old ones still work, only my multimeter ain't very accurate anymore.
                        what shoud I check next?
                        (I got repair kit including C801, C892, C901, C817, IC829, C877, C878, R817, R818,R819).
                        • mitsu79
                          • Mar 2013
                          • 14
                          • Finland
                          I replaced all but SMD resistors, they measured ok. 33uF condensator was 25uF, all other old parts measured more of less same as new ones(excluding transistor, not sure how to measure them). I'm somewhat sceptical, that problem were within these parts, but haven't got chance to test the PSU yet.
                          • mitsu79
                            • Mar 2013
                            • 14
                            • Finland
                            Tried it today, no differense, backlight turns on, but no picture.
                            I measured some voltages and I don't think that the problem is in PSU, what could i try next?
                              What voltages did you measure?
                              Did you check the voltage across the big 450V capacitor?
                              • mitsu79
                                • Mar 2013
                                • 14
                                • Finland
                                Main cap was 385V, others were 24,5v 12v 2v 3,3v 5v and yellow wire mentioned "https://www.badcaps.net/forum/showthread.php?t=25740&highlight=32FLD760P&page=2" post: 32, was 12v as it should.
                                  Those are good, so I would say looking elsewhere would be a good idea.
                                  • mitsu79
                                    • Mar 2013
                                    • 14
                                    • Finland
                                    I think so also.
                                    Which one is T-CON board and is it same as graphics board?
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • JJAAMM
                                      by JJAAMM
                                      Problem
                                      07-06-2023, 06:01 AM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                      Acer TravelMate B118-M-C878 Notebook B Specification for Upgrade or Repair
                                      This specification for the Acer TravelMate B118-M-C878 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B118-M-C878 boardview and B118-M-C878 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 08:32 AM
                                    • Mgiffune
                                      by Mgiffune
                                      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                      I ordered a supposedly β€˜new' Tcon board this time, and
                                      06-09-2024, 10:28 AM
