LG PDP42V64041 not turn.
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    when I press the cross to turn the two front panel LED does not light up.
    The relay card supply (psu-42lp 490m) slap STDBY 5V signal connector CN801 is 5v.les voltages Va and VS are normal, 5 seconds later, the relay reclaque the screen remains black .... .....
    P1 OF Z-SUS connective disconnected, I press the cross to turn the two front panel LED does not light, may controller module B / D D17 D13 D12 D11 lights three seconds after D13 D12 D11 in this, D13 is flashing.
    Does someone could help me
    Thank you in advance for your help
  • Journey11
    Samsung TV won't turn on ... keeps cycling the power relay on & off
    by Journey11
    Hi All,
    First time posting here ... my name is Kevin but my friends call me Journey.
    I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
    After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
    It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
    07-04-2024, 02:44 PM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • Woodsworth
    PS3 CECHC03 60GB YLOD Troubleshooting
    by Woodsworth
    I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
    START
    Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
    03-19-2024, 07:58 AM
  • robante15
    Acer Aspire 4520 won't turn on after reboot
    by robante15
    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
    If I remove the...
    04-06-2024, 06:50 PM
  • Ledgurra
    MacBook Pro A1425 it doesn't turn on
    by Ledgurra
    hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
    thank you all
    11-09-2025, 06:07 AM
