Is this a symptom of a bad z-sus? Vizio P50HDM
    Re: Is this a symptom of a bad z-sus? Vizio P50HDM
    I'd check the Vzbias voltage, along with the other voltages the Y-sus produces and the Vs/Va.
    • johnboy1313
      • Nov 2012
      • 1959
      Well, now it won't power on. I'm not sure what happened. I push the power button, the relay clicks, Vs comes up partially, a relay clicks again, and it shuts back off. Even with the PSU unplugged from the sustain boards it does the same thing. Can't say that I'm too happy about it.
        Check the power button isn't stuck. Check AC-D. (maybe AC-DET)
        I gave up on repairing these LG IPM sets a LONNNNG time a go for a very, very good and long list of reasons.
        • johnboy1313
          • Nov 2012
          • 1959
          Power button isn't stuck. I found the AC-D pin but I'm not sure how to test it? It reads zero with the meter on 20VDC. I'm right behind you with these LG/Vizio plasmas.
          There are two or three green LED's on the control board (main board). They both come on when the surge protector is turned on. After the relay clicks, they blink different patterns. I'm not sure what they're trying to tell me so I made a video.
          https://www.youtube.com/watch?v=wLICsQcFnWQ
            0V's bad. It should measure 3V or more.
            Can you cut the wire and feed in a voltage through a resistor? The resistor should go to the main board.
            The LEDs on the control board are normal. All lit is bad, they indicate the panel temperature in binary.
            • johnboy1313
              • Nov 2012
              • 1959
              I'm not following you here. There is no wire to the ACD pin.
                Hmm, odd. Which board is that?
                Check the RLY-ON signal.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I'm watching a movie with my kids. I'll revisit this in the morning. Have a good night Tom.
                  That's the power supply by the way.
                    Is it...? Looks quite different to what I'd expect, but I can only see part I guess.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Here's a pic of the power supply. The plug in the pic I posted last night is in the lower right corner next to the fuse holder.
                      Rly-on = 4.6v at power on, at which point the relay clicks and Vs-on jumps to ~4.5v. The relay clicks again and rly-on drops to 4.3v and stays there while Vs-on drops back to 0v. When you push the power button again rly-on drops to 0v.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Do you know how to force this thing on with a resistor?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Nevermind
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Nevermind this one too
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              I had a breakthrough. I got the PSU to work.
                              Vzbias = 97.3V across both resistors.
                              Va = 60V
                              Vs = 189V
                              I don't know how to check or adjust the other voltages on this set.
                                How'd you get the PSU to work?
                                Does the panel now light up?
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Yeah. The panel lights but its still really dim. Vs was too high. I turned it down and the psu came on. I then adjusted it back to nominal.
                                    Have you tried playing with the ramp up, ramp dn etc pots on Y-sus?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      A little. There was no change other than skin tones turning kind of neon.
                                        You may require a scope to make further tests.
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          I've got the scope, where do I take the readings from? I'm looking at the training manual for this panel (see attached). When checking Vs, Va, and Vzbias, the readings match the label on the panel. When checking Vsc and Vy, my meter goes into overload, even when it's set on 1000VDC!!! I can't believe that this thing is pushing +1000VDC and not smoking. I'm afraid to check it with the scope for fear of blowing something.
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
                                          • Novabeau 2
                                            Vizio e55u-d2 55 inch tv service manual & schematic
                                            by Novabeau 2
                                            Hello everyone, I'm trying to find some service manuals or schematics for a vizio e55u-d2 55 inch tv that just conked out the other night. It has no power whatsoever.
                                            Have tried all the reset process that vizio had.
                                            Any Insight to this would be great and appreciated. If you all think it's not cost prohibited to fix let me know. known thank you and have a wonderful day.
                                            04-21-2025, 05:50 PM
