RCA M05WH72S screen stays dark/dim
  • pearljam1212
    • Mar 2013
    I just got this TV free from a family member who says the replaced the bulb not long ago. I know this tv is older and I know it is kind of old but if it would be a cheap fix or easy fix I wouldn't mind keeping it. Now the problem is the screen is really dark even with a room that is dark and the brightness set high. Aside from that I also noticed when I looked at it from a couple different angles I could see around the middle of the screen what looked almost like a lamp reflecting off the screen (Again a dark room). So I am just wondering what would cause this if the lamp was supposedly replaced recently....
  • pearljam1212
    • Mar 2013
    Re: RCA M05WH72S screen stays dark/dim
    didn't see how to close my thread... I just fixed it I took the bulb out and put it back it... it wasn't in there properly so if someone can delete/close this or tell me how thanks!!!!
      Just leave it hear for other users. Nice easy fix.
      Is this a DLP, LCoS or other type of rear projection set?
      • Rozp
        70LE660U dark cloud or black screen with sound.
        by Rozp
        Hello Everyone,
        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
        08-29-2023, 05:25 PM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
