lg42px5d standby issue
  • allnighta
    • Mar 2013
    • 3
    first off a big hello and respects to everyone in the forum
    ok so i got the above model which when powered up the front led cycles through from red to amber then to green and back to red
    checked caps on psu and looked ok but changed 6 of them anyways with a repair kit for that board, tested the VS and VA when the ysus and zsus were disconnected and there are ok at 186 volts and 60 volts
    the plasma powers ok when the ysus is disconnected, so i replaced ysus with a compatible one and it still goes back to standby after starting up so i am starting to think the buffer board could now be at fault, fuses are ok on the ysus and every were else
    any help appreciated
    thanks in advance
  • allnighta
    • Mar 2013
    • 3
    Re: lg42px5d standby issue
    bump
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • proditaki
      JBL ES-150-P standby issue
      by proditaki
      I recently bought a faulty JBL ES-150P subwoofer that was completely dead.
      After replacing 2 open resistors (R255 and R256) in the DC Power supply the unit started working.
      It plays fine. But when it wants to go into standby mode, after 10 minutes, it starts cycling for a while. (see video on youtube)
      The noise from the speaker goes away and i'm pretty sure the interval changes and i only hear one relay clicking on the end (light still goes red/green)
      After cycling for like 30 secs to a minute it eventually goes into standby....
      08-31-2023, 04:15 AM
    • YOUCEF4787
      Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
      by YOUCEF4787
      I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
      Initial Problem:
      The laptop was completely dead, no signs of life, no power LED.
      Action Taken:
      I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
      Current Situation & The Main Issue:
      The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
      09-21-2025, 12:19 PM
    • AleMonti
      LG 55EG910V - no power and no standby light
      by AleMonti
      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
      After checking the basics I did the following:
      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
      11-04-2024, 05:02 PM
