Technika x22/14c Backlight issue..component part number
  • is_it_a_bird
    • Feb 2013
    • 59
    • United Kingdom
    Hi
    Got the TV with backlights shuting off after 2 secs, the two caps have blown on the inverter, took a guesstimate and put some 10pf 3kv caps in, tv booted up and was happily playing away for a few hours, turned it off and on a couple of times no problems, then tried turning on nice little crack and the problem is back.
    I have no schematic nor an idea of what size caps are supposed to be in the inverter, any ideas, should I go with 10/15pf 6kv
    Thanks in advance
    Re: Technika x22/14c Backlight issue..component part number
    3kV is quite small, I would try 6kV for those caps, I know budm usually uses 5~6kV caps.
    • is_it_a_bird
      • Feb 2013
      • 59
      • United Kingdom
      Thank you :o)
      • is_it_a_bird
        • Feb 2013
        • 59
        • United Kingdom
        Sorry, would you stick with 10pf??
          10pF seemed to work the last time... no idea what the originals were??
          • is_it_a_bird
            • Feb 2013
            • 59
            • United Kingdom
            No both blown out the board, cant find any info, have been cheeky and asked an ebay seller to read them off but no response :o(
              Could try the trick "trying to verify if my boards are compatible, as have heard they were also produced with 22pF cap" Has worked before for me.
              • is_it_a_bird
                • Feb 2013
                • 59
                • United Kingdom
                hehe, will have a go at that now...Thank you
                • is_it_a_bird
                  • Feb 2013
                  • 59
                  • United Kingdom
                  Just read on another forum post with the same inverter that they are 9pf 3kv, so I have another fault with the TV, I do not think its a ccfl tube as I have had the tv running with no dim lines, for quite some time.
                  Will have another look now I am not sure if one of the ccfl leads shorts to the frame as the wires do look quite tight around it.
                  • is_it_a_bird
                    • Feb 2013
                    • 59
                    • United Kingdom
                    Fitted new 10pf 3kv caps just in case and it was still the same, replaced the two 16v100nnf caps and everything seems to be working ok
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • G-Sting
                      iPad Pro A1876 SHORT Part Identify Help Needed
                      by G-Sting
                      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                      SO My main concern is what part should i order what should i search the name for ?
                      on Ipad...
                      05-15-2025, 09:30 AM
                    • DanPoka
                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                      by DanPoka
                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                      02-15-2025, 05:05 AM
                    • Comp_Pro
                      No Backlight Macbook A1990 820-01041
                      by Comp_Pro
                      Hello all,
                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                      Tests performed:
                      There is no backlight even with a good screen.
                      Backlight IC is receiving the correct support voltages.
                      Fuse F8400 ok
                      Current sense resistor R8400 ok
                      Backlight IC is receiving 3.3V on enable pin.
                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                      Backlight IC receiving 5V from PP5V_G3S
                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                      05-06-2024, 10:23 PM
