Panasonic TC-P42G10 Plasma - Seven red blinks Dead No power
    Re: Panasonic TC-P42G10 Plasma - Seven red blinks Dead No power
    You could try applying a current limited 5V source to the area, then using freeze spray to locate which components get hot. I've used this before on a T-con board.
    • smartjohn
      • Feb 2013
      • 116
      No, I realize the pain involved, but I'm up for the challenge! I am thinking about ChipQuick solder for any large pin count IC removal. It looks to be a better way. I have not looked at the cost yet so maybe I should reserve my decision until i price it!
      IC501 and IC521 look to be the FET Drivers on mine. M81707FP Mitsubishi chips for both. I don't see any bad resistance on these initially. Did you find shorts on any of yours in circuit?
      • smartjohn
        • Feb 2013
        • 116
        So Tom, you're saying just hang a 5V supply on the 5V_F_A (orB) outputs (w/respect to GND) and set the limit to say 100 milliamps?? Then check for the hot spots? (by seeing which freeze spray spots evaporate first?) Sounds brilliant to me...!
        • tw2005
          • Oct 2011
          • 6458
          IC771 [/QUOTE]Vin to com is about 2.1 Ohms, Vout to com I am getting 6.3 ohms...QUOTE]
          If Vin to GND = 2.1ohms then IC16501 Vcc (pin 11) to Gnd(pin 15) also = 2.1ohms on a 15V line = over 7 amps drawn.
          Have a look at the schematic and see if you agree, I would treat that as bad but is it the V reg or the driver. I'll suggest driver. If you take out the REG and tests good then both input side and output side of that cct has issues. That's my theory
            I think the outputs of those regs are floating, so it'd best to put the 5V source across e.g. the regulator's input or output capacitor. I've used amps, but I was working on a power circuit. If the short circuit is on the order of a few ohms, then 100mA should be fine.
            • smartjohn
              • Feb 2013
              • 116
              I didn't have access to a regulated 5V supply, so I built one from an old ATX computer supply! It's actually not to bad for free.. I am going to use a large resistor to limit current. I found another major issue: diode D725 is a dead short. This would short the 5V_F_A and 5V_F_B outputs together. These both feed the buffer boards and I'm guessing a large backrush of current and/or too high a voltage from some failure on the buffer boards may have killed D725. This this is a super small, one of the smallest SMD diodes I have seen!
              I also received my $5 ea SU / SD boards but I will not test these until the SC board is completely healthy! I plan to replace D725 and then re-check all other previous resistance readings next.
              • tw2005
                • Oct 2011
                • 6458
                You should resistance check those buffer boards first in case you've received bad ones. Just received more bad parts myself from FLATTVPARTS in the UK. Both SD/SU supplied dead short and I even went to the trouble of asking them if they test their buffers!
                I had a win and succeeded in rebuilding 2 of my TNPA5081 SC boards.
                  Yes... no one tests these buffers.
                  And the newer buffers get damaged when the TV Is plugged in while cracked.
                  So I would advise anyone who harvests these parts to check if the TV has been powered up, and not to power it up themselves. A cracked screen isn't ever going to work, so I don't know why someone would bother.
                  • smartjohn
                    • Feb 2013
                    • 116
                    So back on my trek, D725 checked OK out of ckt... so I went with tom66's trick and boosted 5V into the outputs of IC725, IC725 one at a time. I played around with current resistors and finally settled on 2ohm 10watt which was giving me around 500mA. Bingo! IC564 gave me an Ouch! to the touch after about 5min of current. It's the only thing on the whole board that was getting hot that I could tell. I was hanging my 5V input on the output of IC725 (the 5V_F_B supply). This looks to be a Schmitt inverter, TC7SH14FU. Now off to go parts shopping again!
                    • tw2005
                      • Oct 2011
                      • 6458
                      So you removed IC564 and confirmed short across pins 3 & 5 and rechecked the 5v regs again?
                      I managed to remove these much easier using 2 soldering irons.
                      Also check out Q743 & Q810 around that inverter.
                      next to SC20 can you measure resistance TP82 to gnd and also across C563
                      Before you rush off and order a TC7SH14FU, check the physical size. On mine it's a TC7SH14F which is larger than the FU. The panasonic part number for yours and mine are the same and it's just under 3mm wide which also matches the TC7SH14F in the datasheet. Note the chamfered edges on the FU. The F is not.
                      There's 4 of these on your SC board
                      • tw2005
                        • Oct 2011
                        • 6458
                        If you have trouble finding these as it appears they're no longer in production Texas Instruments lists these as compatible SN74AHC1G14DBV. The DBV refers to the case, what follows this ignore as from what I can tell they're all the same. I got my HA from china.
                        • smartjohn
                          • Feb 2013
                          • 116
                          Thanks for the data cross ref. Looks like the TC7SH14F replacement might be the DCK version, since pins center to center are .65mm on both. I'll double check mine before ordering. Still need to check the other active parts in the vicinity. As for checking buffers, what pins do you check for resistance / shorts? What should i see on a good one?
                          • tw2005
                            • Oct 2011
                            • 6458
                            TC7SH14F has 0.95 center, DBV is the correct one for this. DCK will be the FU equivalent. I have both TC7SH14F & SN74AHC1G14DBV in front of me and are exact match.
                            In the service manual, Go to pg35, 10.5 block diagram 4/4. You'll see the SC and SD/SU layout.
                            Connector SU41 pins 2,4,8 SD42 3,5,8,9 2,4,6 SD46 1
                            on my boards which are different model, VSCN_F 220K, VFO 1.8-2Mohms, 5V_F over 4Mohms, SCNR_PRO over 5Mohms.
                            All measured with respect to the ground plate. You may have to switch the blk/red probes around to get a steady reading.
                            You can also in diode mode check gnd plate to all thebuffer output pins, you should not see any shorts. I see 0.7 on my meter.
                            • smartjohn
                              • Feb 2013
                              • 116
                              I am having 2nd thoughts on D725 and may just replace it. The reverse resistance was a little low ~150K in my opinion. Only problem is I can't find it's real part#. The SMD marking is "1_B" but that doesn't show up anywhere i am looking. Any thoughts ? This thing is REALLY small (approx. 2.1mm).
                                150k ohm sounds fine to me... was that in circuit? Many small schottkies are very leaky.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  If you have the manual, you have the part number. Try google and it will literally be staring you in the face and as a bonus the marking 1B matches in the datasheet as well.
                                  • smartjohn
                                    • Feb 2013
                                    • 116
                                    Got it! Part# is MA2J111, 80V, silicon switching diode. And yes, datasheet states SMD code is 1B. This part is now discontinued but has been replaced by DA2J101. Both are Panasonic parts. The 150k was out of ckt. I will probably hold off on this one as I have alreday sent my Newark electonics order in and don't fell like paying another $10 buck for shipping until I have some other parts on my list.
                                    Also, IC564 did confirm a short across pins 3 -5 out of ckt.
                                    • smartjohn
                                      • Feb 2013
                                      • 116
                                      With IC564 removed (waiting for new parts) TP82 to gnd is about 4.4K.
                                      Across C563 measures approx. 153K after it settles.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Hey gentleman.
                                        So here I am browsing the forums and amazingly I am having the same similar issue with my tc-54ps1 utilizing the same ysus sc board except all the components mentioned in this thread test good. I'm getting the 7 blink and when I disconnect the sc from the circuit 6 blinks and hear a wuick fireup on the ss board. So ysus defiantly has an issue. I have ohmed uou the su and sd board and all chips are in spec at around 5.5 m ohms
                                        So I'm kind of in the same boat. All the inverters on the sc
                                        Board seem fine and getting voltage at sc2. Interestingly I'm getting a momentary voltage at the screw lugs of the buffers so vscan is trying to come up as well as all the other voltages on the sc board at the test points. I have tried the one buffer board at a time with no success. Any ideas?
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          Originally posted by freakaftr8
                                          Hey gentleman.
                                          Found something interesting not sure if this will help or not but on pin 1 and 5 of ic773 is shorted both ways. Could someone verify if this is correct? Thanks and hope this helps add into this tnpa4844 board debunking
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                            11-24-2024, 11:27 AM
                                          • nick31
                                            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                            by nick31
                                            My Oct 2012 panny plasma quit working yesterday.
                                            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                            04-21-2021, 09:56 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
