I'm having a problem with the color on this tv. There is an abundance of red & green pixels. It also has a vertical line on the right side of the screen It powers on with video & sound.I noticed 3 LED's on the logic board. Two of them were on (2000 & 2003), the third one (2002), flashes at all times the power is on. I found & replaced 2 bad caps (C8046 &C8051) on the power supply, pcb# LJ44-00144A. I just discovered a cap that looks questionable (C8080), & am going to replace it. I also found several diodes that appear to be bad, they have backward capacitance. They are D8009, 8014, 8016, 8019, 8024, 8034, & 8039. On the Y-SUS pcb# LJ41-04217A, i found a bad pico fuse #F5200, plus mosfets under the long heat sync that appeared to be shorted across the outer legs. They are D5001, 5003, 5005, & 5006. I am new to this, so any help would be appreciated. The photos will helpfully show what im getting on the screen.
PHILIPS 50PFP5332D/37 Red & Green pixelation
Tags: None
Re: PHILIPS 50PFP5332D/37 Red & Green pixelation
Moved out of FAQ.sigpic
(Insert witty quote here) -
What caps did you replace them with?
Tell us the original caps specifications and the replacement caps specs.
Also, try a factory reset before anything else.
Should be a button combination on the tv/remote.Do NOT touch heatsinks when testing for voltages as they may be LIVE!Comment
Looks like X-Main issue, but possibly also a Ve/Vset/Vscan or Yrr/Yfr timing issue, which can be fixed by doing some tweaks on the boards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Gilly 1984- The bad caps were 25v 680uf, i replaced them with 35v 680uf. I tried the factory reset & it didnt make any difference.
Tom66- I adjusted the vs from 189 up to the specified 205 & some black around the edge of the screen disappeared.After i changed the first two caps the vs voltage dropped, so i tried adjusting it again but couldnt get it to go above 200 with the pot turned all the way up. The va was ok, i didn't check the others. i am changing the other bad cap i discovered & will reinstall the boards & see if there is any change.
As far as the Y-SUS goes im questioning my troubleshooting on it. I'm confident that the pico fuse is bad because it is open. Likewise the diodes shouldn't have backward capacitance. But i'm not quite sure if i'm right on the mosfets. I noticed all of the ic's on the Y-buffer boards get hot enough that i can only touch them with my finger for a few seconds. It seems to me that they shouldn't be working if all of the components i listed on the Y-Sus arent working.
I will go through the "guide to troubleshooting common plasma tv problems" again to make sure im not missing something. I will also post a picture of the back of the tv & check & post the voltages on the psu. I will also disconnect each board again to see if there is any change
How do i check the X main to see if it has a problem? I obviously don't know much about what i'm doing, but i can follow instructions on how to troubleshoot so any help would be appreciated.Comment
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-12-2024, 02:00 PM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...09-07-2024, 03:10 AM
This specification for the Acer Aspire Aspire Vero Green PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire Vero Green PC boardview and Aspire Vero Green PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 02:20 AM
- Loading...
