HELP Please with faulty TV
  • Berts
    • Aug 2012
    • 55
    • Scotland
    I wonder if you can help I have a Toshiba 32V500B. After a while of being on 1 min or so, a red hue appears on the screen and gradually gets worse.
    So far I have changed the inverter, power board and output boards.
    What else could it be?
    I will attach 2 pictures to show you before and after 1 minute of being on.
    regards
    Berts
    https://www.dropbox.com/s/uxy2r5a67w...2000.54.12.jpg
    https://www.dropbox.com/s/p5vswcwijourrty/IMAG0317.jpg
    Re: HELP Please with faulty TV
    There should be an additional letter before "V".
    Looking at the menus I'd say you've got a Vestel built Toshiba (if that letter is a "B", "D", "S" or "K"), which is the same as a Bush or Alba or any other supermarket cheapie. (You would be right to be disappointed if this is the case.)
    A lot of bad panels on these models, due to tab bonds. It is usually fixable though.
    • Berts
      • Aug 2012
      • 55
      • Scotland
      Ah yes "K" my bad. Its not actually my TV but said I would fix it, thinking that if I replaced all the boards as I have done with others that would sort it. But no joy
      How would I fix these "tab bonds" and where are they situated?
      Thankyou for your time too, really appreciate it.
      Bert
        The tab bonds are on the edges of the LCD panel itself. The operation is difficult but typically achieves over 90% success rate.
        Different faults, but same base cause:
        https://www.youtube.com/watch?v=xHst6pKLtTE
        https://www.youtube.com/watch?v=purk_SyiT44
        • Berts
          • Aug 2012
          • 55
          • Scotland
          Excellent thanks for your help Tom I will post back how I get on.
          Respect
          • Berts
            • Aug 2012
            • 55
            • Scotland
            Ok, so I tried looking at the tabs and no help.
            I thought that if I uploaded a video for you that might help?
            https://dl.dropbox.com/u/74442358/20...2023.23.37.mp4
            I really am stuck with this one ???
            • Berts
              • Aug 2012
              • 55
              • Scotland
              Does that link work ok for you guys?
                Downloading it now, slow internet.
                • Berts
                  • Aug 2012
                  • 55
                  • Scotland
                  Yeah its a big file too HD
                  • Berts
                    • Aug 2012
                    • 55
                    • Scotland
                    Any Ideas Tom?
                      Sorry, forgot entirely about this post.
                      Red hue slowly fading is T-con or panel, or perhaps the supply voltage to the T-con.
                      When the hue appears have you tried pressing the bonds? On the IC as well as the bond->LCD and board->bond areas?
                      Also, try slowly and carefully heating them with a hairdryer to see if you can get the effect to occur quicker.
                      • Berts
                        • Aug 2012
                        • 55
                        • Scotland
                        Thanks, I will have a play tonight and repost my findings, thanks again for your time.
                        • Berts
                          • Aug 2012
                          • 55
                          • Scotland
                          Tom, I tried the points you noted above and cannot get any reaction. I did however find that if I let the red hue start and then removed and reattached the T-Con ribbon cable the hue disappeared instantly?
                          I have included another video for your review if you wouldn't mind taking a look and sharing your thoughts?
                          https://dl.dropbox.com/u/74442358/VIDEO0029.mp4
                          Regards
                            You may have a loose cable, temperature sensitive component or cold solder joint on the T-con. Regional heating or freezing using cold spray (compressed air works too) may help find where the problem is.
                            • Berts
                              • Aug 2012
                              • 55
                              • Scotland
                              Yes I have tried cold spray and could not find the cause. If it were a temperature sensitive component I would assume that unplugging the T-con and re attaching it so quickly would not have the effect I am getting. The hue takes just as long to come back after the quick unplug as it does if I start the panel from cold.
                              Do you think the re flowing the T-con panel would help. I have various equipment round here to do it. I could even use a hot air wand to resolder each component if you think it will help?
                                I think that would quickly risk damage to the LCD panel. It's not removable from the panel. Other things to check would be the supply voltage to the T-con.
                                • Berts
                                  • Aug 2012
                                  • 55
                                  • Scotland
                                  Not sure I know exactly where to test for the voltage.
                                    There should be a fuse on it.
                                    http://www.google.co.uk/imgres?imgur...9QEwBg&dur=571
                                    Voltage is measured at both ends with red probe on each end, black on chassis.
                                    • Berts
                                      • Aug 2012
                                      • 55
                                      • Scotland
                                      Tom, I am getting 11.95v across the fuse. I am guessing that is good?
                                        Sounds good; is it stable when the picture goes red?
                                        • JarzabekPZ
                                          HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                          by JarzabekPZ
                                          I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                          08-08-2025, 03:40 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
                                        • nrj1982
                                          Lenovo Ideapad3 NM-C821 faulty motherboard
                                          by nrj1982
                                          Hello all,
                                          I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
                                          I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
                                          I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
                                          Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V...
                                          10-04-2025, 10:08 AM
