Re: HELP Please with faulty TV
Oh well skip it is then!!
Not a matter of it being worth it -- it's simply impossible without the equipment, sadly. Now, they COULD make the connectors removable (the density is low enough for that to be OK), but they don't.Leave a comment:
So there is no way its even worth me attempting? Man I hate this throw away society that we live in!!
Thanks a lot for your help Tom66 I really appreciate your time.Leave a comment:
A multi-million pound laser welding machine and precision alignment equipment.Leave a comment:
No I have tried each component and there is no joy. I know you say you cant replace the T-con but I wouldn't mind giving it a go. Don't suppose you know what soldering technique they use to attach it to the panel?Leave a comment:
It's a shame the T-con can't be replaced. Does any other part on the T-con respond to freezing?Leave a comment:
That's a negative, absolutely no change when either of the tabs was frozen. The only thing that cures it is disconnecting the t-con then reconnecting. The hue doesn't come back straight away but takes the same time as if starting from cold.Leave a comment:
Try freezing one tab bond or the other and see if it immediately gets better.Leave a comment:
Yes it stays on 12v. Where do you think I should look next or do you think I should just give up?Leave a comment:
Seems fine then. It's pretty much guaranteed to be t-con or panel, sadly, I think something on the panel is knackered. Can you get hold of a can of freeze spray?Leave a comment:
Tom, bang on 12v that's whilst the set is doing its red hue thing.Leave a comment:
Sounds good; is it stable when the picture goes red?Leave a comment:
Tom, I am getting 11.95v across the fuse. I am guessing that is good?Leave a comment:
There should be a fuse on it.
http://www.google.co.uk/imgres?imgur...9QEwBg&dur=571
Voltage is measured at both ends with red probe on each end, black on chassis.Last edited by tom66; 03-13-2013, 11:43 AM.Leave a comment:
Not sure I know exactly where to test for the voltage.Leave a comment:
I think that would quickly risk damage to the LCD panel. It's not removable from the panel. Other things to check would be the supply voltage to the T-con.Leave a comment:
Yes I have tried cold spray and could not find the cause. If it were a temperature sensitive component I would assume that unplugging the T-con and re attaching it so quickly would not have the effect I am getting. The hue takes just as long to come back after the quick unplug as it does if I start the panel from cold.
Do you think the re flowing the T-con panel would help. I have various equipment round here to do it. I could even use a hot air wand to resolder each component if you think it will help?Leave a comment:
You may have a loose cable, temperature sensitive component or cold solder joint on the T-con. Regional heating or freezing using cold spray (compressed air works too) may help find where the problem is.Leave a comment:
Tom, I tried the points you noted above and cannot get any reaction. I did however find that if I let the red hue start and then removed and reattached the T-Con ribbon cable the hue disappeared instantly?
I have included another video for your review if you wouldn't mind taking a look and sharing your thoughts?
https://dl.dropbox.com/u/74442358/VIDEO0029.mp4
RegardsLeave a comment:
by JarzabekPZI have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
by SpudgunHello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
Channel: General Capacitor Questions & Issues
by b-slayerHello.
I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
- first one is to modify le bios to disable the onboard ram.
- second one is to disable the onboard ram by desoldering some components on the mainboard.
so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
so i found that my motherboard... -
by brispussPurchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),... -
by nrj1982Hello all,
I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V... - Loading...
