Vizio LED TV possible purchase
  • tibimakai
    • Jan 2012
    • 3680
    I have found this TV and I know that Budm had this issue in the past and it wasn't fixable, due to corrosion on the tab contacts.
    I don't have a model number yet.
    Here is what it states:
    "I have this 42" Vizio LED TV as stated above. I spilled water on the front of it and now the picture is messed up.
    Hazy picture and solid white lines going through the display."
    Re: Vizio LED TV possible purchase
    Any water damage on newer panels is catastrophic.
    • cashkennedy
      • Aug 2011
      • 668
      You could ask the seller if the liquid was spilled on the screen, or over the top of the unit. If it was spilled over the top of the unit it might have got in a vent and just killed the tcon, but more likely from the errors its giving, it leaked down the front and corroded some panel IC's. Either way i wouldnt spend more then 30 dollars including gas for it cause youd most likely only be able to recoup that by selling any good boards / LED strips.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
        04-09-2023, 08:04 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • JumpyMan
        Aspire One ZA3 Netbook Keyboard ~ Spilled Water
        by JumpyMan
        Hi! I have an old Acer Aspire One Netbook ZA3 model running Windows XP. It's many years old and all that we've ever used it for was to run iTunes for our show sound system. It's always been great for this purpose. Anyway, long story short, I spilled water in the keyboard before a show, couldn't shut it down as we needed it for our music, tipped it upside down, dumped as much water out as possible, shook it, blew on it, etc. and it basically worked fine except for the keyboard. No function at all but the netbook worked fine for many years using a mouse. Lately, the mouse is starting to not function...
        11-20-2022, 03:51 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
