Samsung LCD moving thin colored lines
+ More Options
Posts
  • Alex400
    • Feb 2013
    • The Netherlands
    I have a Samsung LCD with thin moving colored lines.
    See the movie below:
    http://www.youtube.com/watch?v=MojYGN0CM4E
    These lines are moving and everytime the image is different.
    I checked all caps on the main and PSU and replaced them with brand new ones.
    I also tried another tcon board but that gave a totally different image.
    (lines not moving) and when put the old tcon back it gave the moving colored lines again. So I think the tcon is faulty.
    I already ordered a brand new tcon to see if this solves this problem.
    But does someone recognise this problem?
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung LCD moving thin colored lines
    Did you remove clean and replace the LVDS cable ( if reversible did you you get it the right way round)
    • polaro
      Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
      by polaro
      Greetings,
      I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
      08-27-2022, 08:46 AM
      09-07-2024, 05:50 AM
      HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
      This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
      09-06-2024, 06:50 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
