i have a sony kdl40" the audio is present but blacklight and no picture please help me to fix it
how to fix no picture on sony kdl40
Re: how to fix no picture on sony kdl40
Can you tell us the model # of the set e.g. KDL-40X550.
Also can we have some pictures of the electronics inside.
What tools do you have - digital multimeter?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Also i cant tell if your saying the backlight does not light up? or does it light up? (you should see if there is any glow from the screen in a completly dark room, while the set is on)Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
it is sony bravia model : KDL-40V2000, t-con board model is 400wsc4lv004 , the inverter code is csn303-00 A06-126268 ,a06-126269 the audio is ok and the backlight also ok after verifuying in dark room , one tecnician had propose to change the two item inverter and t-con , i ordered to a t-con boardComment
I would suggest waiting for the t-con. If that does not fix it, then we can look at the main board or LCD panel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Please let us know if it fixes it even if you are done repairing the TV. So we can keep track of common faults.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Glad to heat it's working good.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
g day im new here and was wondering if you have heard of digital reception problems with the Sony bravia kdl-32d3100Comment
However, I have heard of digital reception problem with just about any TV.
Check antenna, cables, firmware updates for TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
by noisykid5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
by iglitareHi,
Or is it always a bad/shorted... -
by tree5656This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
by DKWS89Hey Guys,
So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons... - Loading...
