Samsung PN51D550 unable to power on
  • hatechildren
    • Feb 2013
    • 8
    • us
    The TV turned off yesterday in the middle of watching it and now wont turn back on (no sound, no image, no response from remote/buttons). There is a 5 double blink LED light flashing where the power button is.
    Unplugging and plugging back in makes the 'on' click that repeats 5 times then stops. A green LED on one of the boards flashes in sync with this.
    I checked the caps and everything looks normal. My guess is a bad power supply, but TVs are far from my specialty. Any help would be appreciated!
    Here is an album with pictures and close ups.
    http://imgur.com/a/1NWxW
    Re: Samsung PN51D550 unable to power on
    A very common failure on this set is the X-main:
    http://i.imgur.com/GImFfG3h.jpg
    Unplug all connectors from it, except the two brown ones going to the plasma panel.
    Then re-attempt power on.
    • awyatt2
      • Feb 2012
      • 407
      • america
      look on the heatsink rail you will find a pair of diodes they have three legs in a to220 case. the symbol is on the case dont remember if they are common anode or commom cathode and may be one of each. check it with ohm meter in diode setting. u may find the problem here. had three of them in three different samsungs same model, to fail and they have held up since i repaired them.i had a couple of old atx power supplys i borrowed the diodes from, tv is worth more than the powersupply.also you might want to run the caps with an esr meter to be sure. and there is a possibility this is not the problem but it is a weak area. one of them i am currently using now it is the 55d550. been using for over a year now. wife has it on most of the time.
      • hatechildren
        • Feb 2013
        • 8
        • us
        OK, I will try both of these when I get home and let you know how it goes. Thanks!
        • hatechildren
          • Feb 2013
          • 8
          • us
          It looks like I've misplaced my multimeter, so Ill have to wait on that test. But unplugging the xmain still has the same issues. Any other suggestions that wouldnt require a multimeter?
            Try with Y-main disconnected -- opposite board to X-main.
            • hatechildren
              • Feb 2013
              • 8
              • us
              Unplugged, and still has a clicking relay. I tried with only the main-logic and main-misc connected and it still clicks. With the main unplugged, no clicks.
              • hatechildren
                • Feb 2013
                • 8
                • us
                any other suggestions to try? or would anybody recommend which board to just replace and hope for the best?
                  Here is one test:
                  - Unplug main board power connectors
                  - Disconnect main board to control board LVDS
                  - There is a four pin square connector on the board. Jumper pins 3-4 of this
                  Then power on set by plugging in... do you get test patterns.
                  • hatechildren
                    • Feb 2013
                    • 8
                    • us
                    Here is one test:
                    No test patterns. but the relay doesnt click right away (it does once after a few minutes) and the red LED on the power button is responding to the remote.
                      Can you check the 5V supply on the control board -- is it steady?
                      • hatechildren
                        • Feb 2013
                        • 8
                        • us
                        The control board is this correct? http://i.imgur.com/oqc4rTvh.jpg
                        Assuming it is, its listed as 5.3v on the board, but im getting a reading of 5.9 when measuring from the power board itself while the 'control' board is unplugged. if its plugged in, im getting a reading of 5.9 breifly before dropping to 0 (this coincides with the relay clicking)
                          Yes, that is the control board.
                          High 5.9V makes me suspicious of your multimeter battery -- can you swap it so we can be sure.
                          • hatechildren
                            • Feb 2013
                            • 8
                            • us
                            Ill have to wait until tomorrow until Im able to get another 9v battery. Anything I should try in the meantime?
                            • tadziuz
                              • Feb 2013
                              • 10
                              Did diodes from ATX PSU had the same markings? Just found one bad in my samsung tv and it is 30G124...
                              • awyatt2
                                • Feb 2012
                                • 407
                                • america
                                they were the same common anode or common cathode. samsung wanted 27.00 each so i used what i had and have been watching it for over a year now. my wife loves this tv. it is only off when she is at work or asleep.
                                • tadziuz
                                  • Feb 2013
                                  • 10
                                  In my case it seems to be a transistor and I can't find a datasheet for it. Found them on ebay but delivery from China gonna take ages Don't see any other options...
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    whats the part number on the item you are looking for?
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      I'm confused, are we talking about 30G124? is that the full number on the casing?
                                      If so and it is a transistor, Toshiba GT30G124 IGBT? N Channel, 430V ,Ic=30A Dc, 200A pulsed ,
                                      • tadziuz
                                        • Feb 2013
                                        • 10
                                        This is the one I found on ebay:
                                        http://www.ebay.co.uk/itm/30G124-Man...item589aec8af7
                                        Anyway Im getting replacement X-Main board tomorrow and see what happens... Also found open fuse on Logic board but afer replacing it relay keeps clicking and front LED flashing even with disconentec x-main...
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
