My personal tv, all of a sudden just got white screen with red blue and green vertical lines everywhere. Took apart found the t-con to have a short, new board was only $30 so just bought new t-con board, came in saturday, put it in this morning, powered up and worked great for about 5 minutes then the same thing again.
Sharp Aquos LC-40C32U Keeps shorting T-con
Tags: None
Re: Sharp Aquos LC-40C32U Keeps shorting T-con
Have you checked the voltages on the secondary side of the PSU.. they could be over voltage? How do the caps look? Have you checked any fuses on the t-con board or any of the other components to see what blew.. ?Last edited by JonathanAnon; 02-11-2013, 04:31 PM. -
haven't check psu yet, not sure what is going, i know it's shorting out and making a loud buzzing sound the moment you turn it on from the t-con board.Comment
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
Hi everyone. [Sorry for the long, detailed post in advance].
I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard.... -
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by jonah1024Hello!
I'm a few days old into this TV screens repair universe so please bear with me.
Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
- I did the classic unplug and hold power button to discharge the caps but it didn't help.
- I did a factory reset as well...5 Photos - Loading...
