I am hoping that someone can help me out with this TV. This is what it does:
After the power button is pushed, multicolored bars appear on the right side of the screen.
Then the screen goes dark for a split second, then the bars come back with the video image showing on the rest of the screen but kind of dim, the sound works correctly.
A split second after you can see the image the screen goes dark and you can no longer see any images, the sound continues to work.
I have attached an image of what the screen looks like when you can see the video image.
Every capacitor looks good visually and are good brands. It seems I may have two problems, one being the vertical stripes and the other 2 Seconds to black. Could one problem be causing the other? If the TCON board is bad could that cause both the lines and the back lights to turn off? Suggestions on which problem I should troubleshoot first and what part I should concentrate on would be much appreciated.
Thanks,
Lloyd
Thanks,
Lloyd
