Lowew CRT TV
  • shorteddiode
    • 221
    Lowew CRT TV
    Lowew CRT TV model # PLA350PL, has anyone had any experience with this make? I was told it is German made but googeling doesn't turn up that model. I tried Elektro
    Tanya but no luck.
    It turns on with a blue screen and some whit horizontal lines. After about 5 seconds the picture starts to turn white and it shuts down. It stays in standby, and there are no obvious defects on the boards
    could the Video output amplifier TDA6111Q be causing this? There are 3 of them on the neck board
    Re: Lowew CRT TV
    Doubt German made. Probably Vestel. Need the chassis code which will be written on largest board in set.
    • shorteddiode
      • 221
      Re: Lowew CRT TV
      It has a Phillips CRT. The numbers on the board are
      87 185 001576
      062
        Re: Lowew CRT TV
        Thinking about that I don't think Vestel has every sold out of Europe. So it might not be made by them. Any part #'s on the boards aside from those?
        • shorteddiode
          • 221
          Re: Lowew CRT TV
          No none that I found, I'll get some pics posted. I checked the HOT and the caps on the main board and all are good
            Re: Lowew CRT TV
            I'm not really into CRT TVs but I know the basic operation of them.
            If you've got horizontal scanning the HOT's probably OK. Same if you've got a lit screen. Bad caps can cause vertical deflection issues.
            • shorteddiode
              • 221
              Re: Lowew CRT TV
              It uses 3 Phillips video amps on the neck board and since it fades to white before it shut downs I am suspecting one of them
                Re: Lowew CRT TV
                Perhaps, check B+.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: Lowew CRT TV
                  Sounds like that POS 2005 RCA CRT TV (except for the lines) that's now in the back yard, about to be covered with snow!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • shorteddiode
                    • 221
                    Re: Lowew CRT TV
                    I figured B+ was good since it turns on and I do get a picture for a short time. I am thinking like shut down circuit, but can't find a schematic for it. Would the video amps cause a shut down if one was bad?
                      Re: Lowew CRT TV
                      Perhaps if they are providing excessive load. I'm thinking one of the supply voltages is collapsing. Best way to be sure is to measure them.
                      • shorteddiode
                        • 221
                        Re: Lowew CRT TV
                        OK< I'll get some voltage measurements and photos and post the tomorrow.
                        Thanks everyone
                        • randtek
                          • Oct 2011
                          • 280
                          • US
                          Re: Lowew CRT TV
                          I haven't done much CRT work in the last 3 years, so this is reaching back into the cobwebs a bit. The problem you are describing sounds like a grid short in the CRT to me. Try adjusting the Focus pot on the flyback. If it affects the screen brightness, or if the screen control affects the focus of the lines, it would tend to confirm this. Measure the G2 voltage (the small wire coming from the flyback to the CRT board, the one that DOES NOT go into the CRT socket, it will be soldered straight into the board. The voltage on that wire will probably be in the 200-300 volt range, so be careful. Turn the focus pot on the flyback up and down while monitoring this voltage. The focus control should not affect it. The screen control WILL adjust it, probably a range of about 70-400 volts. If the focus pot causes the G2 to change, you have a grid short. Even if these tests don't show anything conclusive, it could still be a shorted CRT.
                          If it was just a blue screen with white lines, I would say it could be a video drive. The fading to white and shutting down scream shorted CRT to me.
                          • shorteddiode
                            • 221
                            Re: Lowew CRT TV
                            I have a CRT tester/rejuvenator I have never used. Guess it's time to break out the black box and see what it can do. I'll run the voltage tests you suggested first randtek. I'll post the results
                            • shorteddiode
                              • 221
                              Re: Lowew CRT TV
                              I payed a little more attention when I turned on the TV and heard an arching noise coming from the picture tube. So sent the TV to to that big repair shop in the sky.
                              • SHONE984
                                G51J asus rog and problem whit bios password
                                by SHONE984
                                hello frends
                                . i have G51J asus rog and problem whit bios password. ALT+R not working. any help....
                                11-23-2022, 01:47 AM
                              • Flybacks
                                CRT TV - Blue spark inside glass neck related to focus
                                by Flybacks
                                Hello, when I power on the TV there is a blue little spark inside the crt glass neck that increases and decreases in intensity with the focus, when focus pot is at minimum it is invisible when it is at max it is brighter and makes some dots on the screen appearing and disappearing randomly.
                                The picture is fine and the TV has no problems.
                                I've cleaned the crt plastic socket, pins and the spark gap contacts so I don't understand what could cause it
                                Could some more experienced member help me to troubleshoot it ?
                                Some picture attached for better...
                                12-01-2021, 01:30 PM
                              • kimiarayan48
                                asus k555ld rev:3.3 whit battry capacities 45% display is blinking
                                by kimiarayan48
                                hi i have asus k555ld rev:3.3 whit battry capacities 45% display is blinking
                                uper 50% battry no problem and whit adaptor no problem
                                thanks helpe me
                                07-01-2020, 11:45 PM
                              • ruzhda
                                Clean Bios dump for HP 260 G4 mini
                                by ruzhda
                                I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
                                I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
                                I need clean dump to write new IC chip.
                                07-21-2024, 08:10 AM
                              • bouch
                                unlock macbook air A1932 2019
                                by bouch
                                hi
                                i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                I need help or information?
                                Does anyone have the minat2 activator 1.4 software?
                                Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                Thank yo...
                                03-12-2025, 10:14 AM
