samsung lns4692dx audio ok, no video
  • dejesus
    • 108
    • usa
    Re: samsung lns4692dx audio ok, no video
    sorry tom, but i am getting a little confuse. This board don't have a pico fuse so i imagen you refering to the one on b1. Anyway, no matter were i check is giving .98vdc maximun
      It has to have at least one surface mounted fuse on the T-CON board.
        I have never seen a t-con without one. I think since the LCD panel is a module that Samsung buy (from themselves but another part of the company) it is required by some safety legislation. Seems odd to me, though.
          Still waiting for the picture of the T-CON.
          • dejesus
            • 108
            • usa
            Good day everyone. I begining to like this.I was not sure wish one was the fuse and i desided to go and do some reseach and i found that some, other than the pico fuse have a letter p on top. EUREKA!! I found it. I tested it and it have 5.v one way and.7v the other way wish for me i think is bad. what do you think?
            • dejesus
              • 108
              • usa
              #26
              this is a better picture. the fuse is in CP1
                What voltage on both sides of fuse, with black probe on the chassis?
                  Originally posted by dejesus
                  i check the 4 voltage regulator, 3 of the are getting about 7 volt in and 1.8 to 2.2 out execpt on one that get about 7 v. in and the same amount out.
                  If the fuse is open, I wonder how you get the 7v feeding the LDO.
                  • dejesus
                    • 108
                    • usa
                    #29
                    i don't know but iam getting .78 dvc
                    • dejesus
                      • 108
                      • usa
                      #30
                      sorry i mean .78dcv
                      • dejesus
                        • 108
                        • usa
                        #31
                        do you think is a good idea to do a bridge on it and if yes from wish point to ....
                          With TV unplugged, What resistance do you get when you measure the two pads of the fuse?
                          • dejesus
                            • 108
                            • usa
                            #33
                            with the tester onvdc auto and the black probe on a t-con screw i get .28 in one side and .66 in the other.
                              OK, so it is not getting power. Can we have close up shot of main board?
                              • dejesus
                                • 108
                                • usa
                                #35
                                  You did test it with that LVDS cable (t-con -> main board) plugged in, right?
                                  • dejesus
                                    • 108
                                    • usa
                                    #37
                                    yes.
                                      Schematic:
                                      http://www.tgohome.com/ServiceManual...&Search=Submit
                                      Near LVDS, do you see C1028 or C1027? Measure the voltage across them.
                                      IC103 is an 8-pin device and may be near LVDS. Do you see that too?
                                        Now you are saying that you no longer has 5V one one end of the fuse? I am totally confused on your measurement. I think we need to start it over as to what DC you are egtting on the T-CON's fuse with the TV powered on and everythings are connected.
                                        • dejesus
                                          • 108
                                          • usa
                                          #40
                                          I found c1028, tested with tv on getting 5.4v could not find IC103. I found IC104 wish is a 8 pin eprom.
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • SolarFlare
                                            Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                            by SolarFlare
                                            My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                            The TCON board has the following Chips -
                                            Samsung VTU63A0
                                            RT6939 - 2nos.
                                            and all these chips are getting real hot within a minute, I dont know if this is normal....
                                            06-26-2022, 08:58 AM
                                          • frannyjunk
                                            Samsung UN32M4500 has audio but no video
                                            by frannyjunk
                                            Hi, I have a Samsung UN32M4500 that turns on, has audio but no video. No Samsung splash screen when turning on, but I can see the backlights (screen is just this dark gray color). The TV only has one board, which I replaced from one I purchased from directtvparts on eBay. But still the problem persists. Is my LCD bad?
                                            06-05-2021, 08:34 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
