Hi, i been reading all the information on this problem and i decided to get in line for the first time. I will try to give you all the inf i can. This tv was giving to me because it power on, you can hear the video but no picture even when i put a flash light close to the screen in a dark room. When i got it i replaced a bad capacitor on the power supply CI824. Other than that i check all the voltage everything find except on CNM801 i am getting 11.98 not 12v. and on CNM802 i am getting 1.3v not 12v. How can i correct that?
samsung lns4692dx audio ok, no video
Re: samsung lns4692dx audio ok, no video
Can we get the close up pictures of the inverter boards, power supply board connectors so we can see the labeling? Power supply board P/N?Never stop learning
Pics are good, sometimes post can get buried if forum is busy.
If you are getting 1.3V on a 12V line I would suspect a failed capacitor that might not appear obviously bulged.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Good pictures, Can I get good pictures on the bottom side of the power supply board as a whole and also four 1/4 section? Same for top side.Never stop learning
Ok. good afternoon. I went ahead and change the caps, some i left because they were good but 90% change. Still have no video but now i have back ligth. I am sending the picture you request. I'll be by the computer if you need me. I want to said thanks to you all for the help i'm getting. JOB WELL DONE!Comment
Great; now we need to check the fuse on the t-con board.
Top centre of this pic: https://www.badcaps.net/forum/attach...7&d=1360010928Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
So you are getting the 12vdc now?Never stop learning
Have you tested the fuse yet? Clear pictures of t-con would help!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, then meter voltage on both sides of fuse, relative to case (black probe on case.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by SolarFlareHi,
My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
The TCON board has the following Chips -
Samsung VTU63A0
RT6939 - 2nos.
and all these chips are getting real hot within a minute, I dont know if this is normal.... -
by frannyjunkHi, I have a Samsung UN32M4500 that turns on, has audio but no video. No Samsung splash screen when turning on, but I can see the backlights (screen is just this dark gray color). The TV only has one board, which I replaced from one I purchased from directtvparts on eBay. But still the problem persists. Is my LCD bad?
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
- Loading...
